Old 05-26-2011   #11
Default Re: DuAL Clutch Setups
So who wants one?
Old 05-26-2011   #12
I actually want to have Pete check them out before I would sell them
Old 05-27-2011   #13
Took these apart, they are in great shape....
I guess the one thing I missed about the Steel setup was that the TO bearing was clean none of the grub you see on a used set up.
Measured the disc... one if 7.9mm and one is 7.6mm, I measured the new one I have for the stock setup and it measured 7.9 the steel setup still has the orbital marks were they prepped the clutch surface. I would say this one only has a few passes, and the steel is supposed to be the best street setup
The aluminum seems to have a few passes on the clutch discs, but there is meat there....all of the internals are the same on both.
If someone has an interest on these I would be open....I could easily swap the clutch discs from the steel to the aluminum if some wanted it.
Let me know....
Old 05-28-2011   #14
Exactly!
I would think you could abuse them and power shifting would not be so rough on them.....I believe best times in the ZR-1 are with powershift technique.
Just ask Jim Ingle!
Old 11-29-2011   #15
chris313scorpion
either still available?
chris313scorpion is offline   Reply With Quote
Old 11-29-2011   #16
Scrrem
Scrrem's Avatar
Pm'd you.
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
