#11 |
![]() Join Date: Mar 2010
Any more pix showing the rocker panels on that Red '90? Thx.
[COLOR=red][SIZE=1][FONT=Arial Black]1991 Red/Red [/FONT][FONT=Arial Black]Haibeck 350 500 HP [/FONT][/SIZE][/COLOR][LIST][*][SIZE=1][FONT=Arial Black][COLOR=red]Corsa Exhaust and [/COLOR][/FONT][FONT=Arial Black][COLOR=red]4:10 Dana 44 gears[/COLOR][/FONT][/SIZE][/LIST][COLOR=blue][SIZE=1][FONT=Arial Black]1994 Admiral Blue/[COLOR=silver]Grey[/COLOR] [/FONT][FONT=Arial Black]Haibeck 368 530 HP[/FONT][/SIZE][/COLOR][LIST][*][SIZE=1][FONT=Arial Black][COLOR=blue]DRM Coilovers, [/COLOR][/FONT][FONT=Arial Black][COLOR=blue]Baer EradiSpeed Brakes, [/COLOR][/FONT][FONT=Arial Black][COLOR=blue]B&B 4th generation exhaust, 18" Face Polished Fikse FM5s, [/COLOR][/FONT][FONT=Arial Black][COLOR=blue]4:10 Dana 44 gears, and a BB tranny. [/COLOR][/FONT][/SIZE][/LIST] Last edited by 94Admiral; 04-06-2011 at 10:28 AM. Reason: typo |
#12 | |
![]() Join Date: Feb 2006
FWIW, my 91 has been leaking (slowly) from day one and I just top it off every so often.
#13 | |
Thanks for the heads up |
#14 | |
Check the carpeting on the drivers side. It may be wet from the fluid leaking out of master. Also, if your slave is a replacement, seal on piston may have been installed in reverse. If you pump master and fluid goes black again, keep draining it until you can pump clutch and fluid stays clear. |
