03-23-2011 | #11 |
Re: Serp belt drive noise?
Awesome offer, I was quoted $15 for the pulley and bearing locally but availability maybe a problem, I'll let you know, THANKS!
John Porter '93 Ruby Coupe ZF6 - Muffler eliminators, Blink Blink kit and Polished ZR1 Wheels * PA Plate: OBSSSN '06 LeMans Blue C6 Coupe - Corsa exhaust * PA Plate: OBSSSV ZR1 Net Registry Founding Member #153 40th Anniversary Registry Member NCM Family Membership #8116 Corvette Forum NE Events Coordinator Delco Cruisers Board of Directors SAVE THE WAVE! |
03-23-2011 | #12 |
John,
Sorry to be so slow to reply to your question. Tensioner assembly comes with the pulley. You can also purchase just the pulley w/bearing. I will have some NOS tensioners and also some NOS pulleys in the next week (I hope). Once they are in, I will put the NOS tensioner assy on special for 5 days at the old price of $145.00 + Shipping. Afterwards, the price will be $156.00. NOS pulleys will be $20.00 special pricing for 5 days, then $24.00, + shipping.
03-24-2011 | #13 |
I bought a tensioner pully/bearing for an LT1 that has worked just fine, FWIW.
As for the source of the sound, I bought one of those mechanic stethoscopes which resulted in me changing the tensioner, AND the PS pump before Marc H showed me how by removing the metal probe and diaphragm from the stethoscope and just using the rubber hose to probe the noise you could better isolate the source. It turned out to be the water pump. P.
03-27-2011 | #14 |
Got a new pulley installed, put the serp belt on and still have the same noise.
Sounds like the alternator, definitely coming from that side but hard to pin point. Going to put my old alternator in and see if it's the alternator and go from there.
03-27-2011 | #15 |
It sounds like you are proceeding in a very deliberate trouble shooting method. Good luck.
Jim |
03-28-2011 | #16 | |
Get your old alternator rebuilt first would be my suggestion. You where going to go there anyway. This way its done in One. GC
03-28-2011 | #17 |
can you record and post a short video of the noise?
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
03-28-2011 | #18 |
Return of the waterpump noise your thinking Jeff?
03-28-2011 | #19 |
Could be,
As per my video, that vibration noise was the Water pump. found out after swapping the tensioner pulley, then the whole tensioner. 2 months after that I had a bird (chirp) under the hood.. this time it was the Alt. I would hate to see him swap the Alt. to find it is the WP. I figured another few sets of ears on the noise might help him find swapping a bunch of parts
03-28-2011 | #20 | |
Handy tip: As for bird chirps, it can sometimes be the serp belt. To eliminate that possibility, spritz the underside of the belt (sparingly) with water or Windex while the engine is running. If it immediately quiets the chirping, then the belt is the guilty party. FWIW, P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 03-28-2011 at 11:25 AM. |
