06-21-2022 | #11 |
Re: 1991 ZR1 engine knocking on idle
I had a spark knock issue which was at least partially caused by ignition coils that presented cracked housings. You can see carbon tracking on the coil surface.
Since you are going to the trouble of a plenum pull, I would also recommend having the injectors flow tested and rebalance the fuel delivery by matching up the injectors properly. You?ll be pleasantly surprised at how much smoother the engine runs.
06-21-2022 | #12 | |
06-21-2022 | #13 |
Did that one also Bob on my 72 Coupe.
07-09-2022 | #14 |
I pulled the plenum and have few more questions.
What could be that black powder that came out from the vacuum line on the passenger side? IMG_20220708_213647.jpg Should I be concerned with the amount of oil on the case ventilation cover? IMG_20220708_224601.jpg Why I don't have a temperature senson on my throttle body extension? Is it a common mod? IMG_20220708_161914.jpg |
07-09-2022 | #15 | |
07-15-2022 | #16 | |
07-16-2022 | #17 |
Yes charcoal pellets from the charcoal evap canister behind the RR tire. The whole line will have to be blown out, the canister replaced, the vaccuum actuator at the canister replaced, and the under plenum solenoid replaced. The canister is ruined by gas getting to it when filling the gas tank to the brim. I have done it all on Quasar.
07-19-2022 | #18 |
Thank you guys for all your inputs. I just assembled the engine after replacing the coils and wires. Now it's finally running smooth. I also blocked TB coolant by the way.
What about the charcoal in the vacuum line, I disconnected the vacuum line behind front right wheel, opened the purge solenoid by grounding the ECM pin and sucked all the charcoal from under the plenum. Then blocked the vacuum line, and left the charcoal canister side of the line open. This is temporary solution for the time I get a new charcoal canister. Can anything bad happen with that solution except of fuel smell? |
