06-12-2012 | #11 |
Re: Change oil light
Thanks for the input. I'll check the light when I get home tonight. I've got the procedure for resetting it.
06-12-2012 | #12 |
Hi
BTW, how do you reset the change oil light ? Thanks Don |
06-12-2012 | #13 |
1. Turn the key to RUN, but don’t start the engine.
2. Press ENG MET on the Trip Monitor. Then, within five seconds, press it again. 3. Witbin five seconds, press and hold GAUGES (or Range button in 90-91) on the Trip’Monitor. The CHANGE OIL light should flash. 4. Hold the GAUGES button (or Range button in 90-91) until the CHANGE OIL light stops flashing and goes out. This should take about ten seconds. When the light goes out, the monitor is reset. If the monitor doesn’t reset, turn the ignition off, then try again.
06-12-2012 | #14 | |
06-12-2012 | #15 |
Checked tonight, when I turn the key on, the change oil light does not come on. Somebody with a 90 wanna do a key check for me and see if the "change oil light" comes on with the key. I don't remember it coming on pre start up.
06-12-2012 | #16 |
I just checked on my 90, and the light comes on for a few seconds when the key is turned on.
06-12-2012 | #17 | |
Mine happens to be a 90.
06-12-2012 | #18 |
Well, maybe I'll run mine until the next oil change and see if the light comes on. I know the first time it came on, it surprised me, like I had never seen it before. Or, maybe the bulb is blown.
06-13-2012 | #19 |
My "Change Oil Light" comes on for a few seconds then goes out with the key on, but not running.
JB 1990 #148 Red/Saddle Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice :cheers: |
06-13-2012 | #20 |
Well you now know the bulb is popped. You'll no longer get a reminder from the car until you replace the bulb. The bulb should not be hard to replace.
