05-09-2012 | #11 |
Re: First Plenum Pull - Code 16
anyone have any luck straightening a pin that's been bent flat .if so how did you straighten it out ?????
05-09-2012 | #12 |
I fixed mine using a very small needle nose. I was gentle as those pins don't look like they tolerate a lot of bending. I bent my pin fairly flat also, kind of into an "L" shape. Just be gentle, and it shouldn't break off. fwiw, so I never do that again, I marked the "top" side of the connector using a red sharpie.
10-13-2012 | #13 |
To all who responded:
This turned out to be a bent pin on the ignition module. It was easily straightened and the car jumped to life, no codes no problems. Repair was postponed due to an A-Fib(cardiac episode) issue, mine not the car , it has been surgically corrected and all is well there as well. Sorry for the delayed resolution. I'll post about a fuel pressure problem that developed 2,599 miles after I first drove it out of the garage under another title. Rich
REBelZ '92 ZR-1 Yellow/Black #031 |
10-13-2012 | #14 |
Sure glad to see you back.
All other things just pale to being back in the saddle. Life begins at 180mph !
10-13-2012 | #15 |
10-14-2012 | #16 |
Number one reason I like this place.... owners helping owners :-)
Number two.....Corvette babes ;-) |
10-15-2012 | #17 |
Holy Cow Rich! I'm glad to hear that the cardiac condition is resolved.
Be Well Brother!
10-16-2012 | #18 | |
I've had A-Fib issues since 2003, It's a pretty common issue. After the 4th Zap to put it back into rhythm since then, when it went out again just 4 month later, I decided to have the Ablation surgery. The heart center has just started using Cryoablation. It was scary, they are messin' with your heart... All went as planed. I almost had a heart attack though(kidding) when I got the hospital bill. For the Prep, Operating room and one night in a semi-private progressive care room, just the hospital charges were $105,650.00... My insurance paid every dime!! Interestingly enough, they wouldn't pay $629.00 of the surgeons $2,500.00 bill. Go figure! Rich "Rebel" Ballou
REBelZ '92 ZR-1 Yellow/Black #031 Last edited by rebelz; 10-16-2012 at 01:16 AM. Reason: Spelling errors - Damnit Jim I'm an engineer not a dictionary! |
10-16-2012 | #19 | |
;-) My vote is on the DIS plug as well. Nearly impossible to get to without pulling the plenum again, but if this is the first time you've seen this code, it is the smoking gun. 'Crabs
10-18-2012 | #20 |
