Old 06-18-2008   #11
ZR-1Mikko
ZR-1Mikko's Avatar
Default Re: Big injector sealing problem
It is back together and started great with no leaks!! It turned out to be the o rings between the rail and injectors. I found about 4 damaged o rings...
Thanks to everyone for your tips
If you don't put the miles on it, someone else will...
ZR-1Mikko is offline   Reply With Quote
