01-07-2014 | #11 | |
Re: Carter, new part,I think.
Here is a REAL Example of KLUDGE if our friend is listening Carter.....Dude.... As you can see I did not leave much rubber hose to work with but enough for some kind of plug.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-07-2014 at 08:31 PM. |
01-07-2014 | #12 |
Dyno,
I'll work some magic and replace that sow's ear......
02-04-2014 | #13 |
I just finished the Bypass Plug for efnfast. In the mail to him tomorrow and hopefully he'll post up a pic before and after. Working on front sway bar relocation brackets, LT5 rear plate, billet throttle line brackets then a project for GC.
95 ZR-1 BLK/Gry #392 LT5 Reg# 868 *RIP* ZR1NET Founding Mem #155 Last edited by carter200; 02-11-2014 at 12:37 AM. |
02-05-2014 | #14 |
I would think something similar to this one. Anything short of "barbed" similar to this I think might fall short. This is maybe an "incorrect" dimension but a correct ID I never did see mentioned. This one is 3/8".
02-05-2014 | #15 |
I run the hoses as if they were operational.
02-05-2014 | #16 | ||
You will find the 3/8 inch Aluminum Barbed Hose Plug here....... 3/8 inch Barbed Hose Plug What else are you faking I run my ZR-1 as if it were stock around CA Highway Patrol......
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-05-2014 at 01:21 PM. |
02-10-2014 | #17 |
Carter stuff just arrived. My plug, oil filter cover, oil filler cover, power steering and brake fluid. Gimme a minute, I'll get it installed.
02-10-2014 | #18 |
PM me with your findings.....
02-10-2014 | #19 |
I used a Gates heat shrink for the plug. Looks the nuts. This is a must if you've eliminated the tb coolant.
02-10-2014 | #20 | |
And Carter.....Just look at my thread and make a Billet Oil Dip Stick Handle.....there is enough information there to crank (excuse me....turn) one out I am sure..... AMSOIL 10W-40 Etched in Red Letters See Item #3 LT5 Lubrication Tricks
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-10-2014 at 10:39 PM. |
