#11 |
![]() Join Date: Mar 2013
Please do! A pair? there are two pumps? My plan is to ultimately go through the top end and replace all the fuel rail seals and fix any vacuum issues. May do some top end porting as well. The injectors are original I believe so I may upgrade those too. At the moment trying to finish up my 95 project involving changing the rear gears to 4.10 and swapping over to a light weight RAM dual clutch set up.
How do you like the 4.10 gears? I hear the lightweight flywheel can be noisy buy I added a thicker counter shaft shim as recommended by Bill Boudreau including his C-Beam plates. It has been a fun project but I am ready to get it done. Everything else has been done to it except secondary system removal. I am in the process of registering the car in a county that does not require emissions testing so I am planning on pull all that stuff out as well now.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp Last edited by KJL; 07-07-2016 at 10:20 AM. |
#12 |
![]() Join Date: Aug 2012
Yes a pair, primary and secondary. If the injectors are original, that is for sure must be done. When I purchased my car in CT it was fine on the test drive and then driving down to MD it started stumbling on the NJ Turnpike. I was lucky to limp home, 7 out of 16 injectors were dead. Thanks to Wazoo, all worked out.
#13 |
![]() Join Date: Jan 2015
I have a spare ECU you can swap in for a quick test. Send me an email if you'd like to get together to try that.
#14 |
Thanks for the offer! I am going to check a couple more things first. Figured I would just go ahead and replace the spark plugs while I am checking them. Maybe run some injector cleaner in the tank as well. Interesting thought....I guess there are only a finite number of ECMs available for these cars. Probably wouldn't hurt to track down a couple of spares.
What is a good plug to use?
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp Last edited by KJL; 07-07-2016 at 12:08 PM. |
#15 |
Just remember that injector cleaner will not fix the issue if it is injectors. Ethanol gas will short out the original injectors, ask me how I know
#16 |
Thanks for the info, decided not to mess with gas additives. So far the problem seems to be getting a little better each time I drive her. I changed out the plugs and the old ones, while old, looked very good. All plugs looked the same. A couple of plugs had oily threads but that is about it. I was reading elsewhere that a bad O2 sensor will also cause issues with lack of power. I would think that would throw a code.....
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
#17 |
![]() Join Date: Apr 2004
Check your O2s.
#18 |
Yes, I need to do that. I am sure there is a procedure somewhere on this forum for doing this.
#19 |
Well, Wazoo fixed my issue. The dealer had not connected the small hose going to the MAP and also my throttle cable was messed up so the throttle was 59% when the pedal was all the way to the floor. The dealer has no clue.
#20 |
![]() Join Date: Feb 2009
Glad Jim got it sorted out 👍
Rich
