Old 04-12-2019   #11
32valvesftw
Default Re: Hard to Start...
Not a fan of HF either, most decent local autoparts stores will also have a fuel pressure gauge.
Originally Posted by Rumblin70SS396 View Post
Paul,
I hate HF but I will head there this weekend! Thank you!
Old 04-13-2019   #12
jss06c6
Agree with Paul.. I turn on the key for about 5 seconds before I crank, and never let go until it starts. Some days are shorter crank times, some days a bit longer..
Sent from my SM-G950U using ZR-1 Net Registry mobile app
Old 04-13-2019   #13
Originally Posted by 32valvZ View Post
Thats how I do it also... I just wait for the vac pump to shut off, then start it.
Vacuum pump? VACUUM PUMP!? WEE DOAN NEED NO STEENKING VACUUM PUMP!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 04-22-2019   #14
Rumblin70SS396
Default Hard to Start...
After reading the posts I think I understand the car a bit better and what I have seems normal. I now let it sit 5 seconds with key on then crank till it starts. When I actually timed it, it took about 3 seconds to fire. I guess I am used to my newer cars and even my high compression Chevelle which fires right up. Either way, it is not cranking excessively.
Thanks again all!!
Rumblin70SS396 is offline   Reply With Quote
Old 04-23-2019   #15
IIRC, it seems I was reading the FSM where I read that it takes the ECM to receive enough signal blips from the reluctor to determine crank position before the spark is authorized. (Someone pls correct me if I'm wrong on this.)
90 #1202
Sans secondaries
