Old 11-09-2017   #11
Ccmano
Ccmano's Avatar
Default Re: 90’ Clutch Hydrolic Line
I wrote an article detailing this in the last issue of HOTB, FYI. After it was published, I heard from someone with a later model (a '94 ZR-1) who pointed out that his car had a spring steel retainer clip on his m/c actuator rod, instead of a "C" (or "E"?) clip I mentioned in the article. (I'd be curious to know whether yours is a "C" clip or the spring steel type. (the spring steel I've seen on other stuff, and quite frankly would be preferable to the "C" clip, IMO.)
Cheers!
Paul,
Removed mine today. I can tell you that my mid-production 90’ has the spring steel clip. Good thing I decided to do the replacement. Turns out the master was leaking slightly on the actuator shaft.
Thanks again for your great article.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
