Old 11-30-2020   #11
Corvette95
Corvette95's Avatar
Default Re: Lot going on..questions about trans R/R, Motor Mounts, and full exhaust
It?s got less at than 30k on clutch, and since a dual mass isn?t available I don?t want to chance getting it out of balance.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 12-01-2020   #12
Also, mark the driveshaft & differential before removing so it can be reinstalled in the same position.
Old 12-02-2020   #13
Corvette95
Corvette95's Avatar
Alright, got all the 8 mm bolts off both sides of manifold heat shields but can't maneuver them off the manifold, FSM doesn't even mention them. How do I get them off, I have the motor mounts support cross members off....update..well it seems I mis-understood, I don't have to remove the heat shields prior to manifolds, just loosen them..if that is the case that's good but I don't see how anyone re-using the stock manifold gets those heat shield screws back in!
Old 12-02-2020   #14
Corvette95
Corvette95's Avatar
I got the drivers heat shield off, can't for the life of me see how the passenger side comes off, can I get to the manifold bolts with the heat shield loose? I am at a stopping point for the day my helper had to cut out, I can see the motor mounts, looks like the passenger is cracked for sure, can't really tell yet...first two photos is drivers side, last two passenger.
Old 12-02-2020   #15
Ccmano
Ccmano's Avatar
They usually crack where the bolt goes horizontally through the rubber. Like I said, haven't seen one without broken mounts yet. The heat shield bolts require extreme patience. I assume you removed the wheel well inner panels for access?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 12-03-2020   #16
Corvette95
Corvette95's Avatar
H
Yes, I removed the inner fenders. Today I hope to get the headers off. Did you need to reuse and header bolt spacers ( planning ahead) with the Mr. Gasket header bolt set? I am also trying to decide to use titanium heat wrap on the heaters instead of ceramic coating...cost and time is a factor.
Old 12-03-2020   #17
Ccmano
Ccmano's Avatar
The header bolts go on as is. They are designed to bite into the header flange with the serrations under the head of the bolts.
H
Old 12-03-2020   #18
Corvette95
Corvette95's Avatar
Default Lot going on..questions about trans R/R, Motor Mounts, and full exhaust
Good Lord, I have to have taken the passenger header off incorrectly. There is no way it should have been that hard. Do these look like oem fasteners with the washers, plus I thought the factor used less bolts than this, how man of the Mr. Gaskets bolts go in..all? and what about the stud to the oil gallery, do I reuse the stock stud? Thanks
Old 12-03-2020   #19
Old 12-03-2020   #20
Your Post #19.....In Post #6 of Solutions "Exhaust Systems"
