03-29-2018 | #11 |
Re: Engine Pull/Install with headers
03-29-2018 | #12 |
The plates are attached to the cylinder head at the water ports.
Image1522340071.892184.jpgImage1522340101.222869.jpg Sent from my iPhone using ZR-1 Net Registry
03-29-2018 | #13 |
Also, the holes in the plates are elongated to allow the 1/2” bolts to rock vertical to connect to the crossbar. The underside of the bolt heads are also rounded a bit to helpout with this. Be sure to run the three 8mm bolts down tight that attach the plates to the cylinder head.
03-30-2018 | #14 |
Thanks Phil. Your engineering, fabrication, and machining are a godsend to the ZR-1 community.
Tony - Tnova |
04-09-2018 | #15 |
Engine is out, project is moving forward nicely. Here’s the lifting hardware I fabricated to distribute the weight. Worked like a charm. Engine was out in 20min.
H
04-09-2018 | #16 |
Look at YOU go!! Great work Hans..
04-11-2018 | #17 |
Hans,
Did I mention retiming the cams before u put it in?
04-11-2018 | #18 |
Hans,
Your lifting solution is another gem for maintaining and modifying the LT5. This community is great. Tony - Tnova |
04-11-2018 | #19 |
Man, I hope I never have to pull another motor. Thanks for sharing all this great info and good job!!
04-11-2018 | #20 |
I plan to at least check the pin locations. Not sure I’m ready to tackle exact cam timing without adult supervision.
H
