11-18-2008 | #161 |
Re: LT5 Assembly Project
Lee,
Is the reluctor wheel removable from the crank? |
11-18-2008 | #162 |
i don't think so, it is in the middle of the crank
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
11-18-2008 | #163 |
11-18-2008 | #164 |
It is integrated into the crank, unike the LS1....I will look closer when I get back home.
LGAFF 92 ZR1 #234 |
11-18-2008 | #165 |
It's one piece.
Pete
11-18-2008 | #166 |
11-19-2008 | #167 |
11-19-2008 | #168 |
For that stubborn bolt some machine shops, if equipped, use an EDM machine to remove the material. Kinda overkill but definetely the cleanest way.
IT IS THE FATE OF THE INNOCENT TO MEET WITH DEATH!!! |
11-19-2008 | #169 | |
Even if this method is used, the threads will still need to be chased or replaced with heli-coil considering the bolt was cross threaded.
11-23-2008 | #170 | |
Here is the response from Calico Coatings, I will probably send them out soon:
92 ZR1 #234 90 # ??? Engine from 90 #702 |
