View Poll Results: Best Sounding Exhaust for the ZR-1
B&B 90 29.80%
Corsa 102 33.77%
Desert Development 3 0.99%
Flowmaster 45 14.90%
Borla 39 12.91%
Power Effects 19 6.29%
MagnaFlow 4 1.32%
Voters: 302. You may not vote on this poll
Old 09-07-2018   #161
32valvesftw
Default Re: Best Sounding Exhaust for the ZR-1
After a while with my set up, which is long tube headers, no cats, x-pipe and Borlas mufflers I am thinking I want something a little quieter. Does anyone have experience with Flowmasters on the LT-5?
Old 09-07-2018   #162
ZWILD1
ZWILD1's Avatar
My first 91 was done by my friend Jeff. He used the small tube Watson headers and the old 3 inch B&B and I thought it was the best sounding. With the 4.10 gears it had that resonance everyone complains about but I loved it cause I'm deaf and just love loud. It was a strong running car with no major engine mods.
So now the new 91 I have has the long tube headers , no cats, and the 2.5 Corsa that Mark installed when he did his engine package. It sounds really great to me. I was considering changing it out to a B&B but I like the older ones. I think the best thing is to not screw with what Mark did especially after seeing the dyno sheet.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
Old 09-08-2018   #163
zr1eddy
I have the Flowmaster exhaust that was designed for the ZR-1. I found the system on eBay, it was brand new without mufflers. I put Flowmaster Delta Flow Series 50 mufflers on. I think it sounds great, to top it off I put Flowmaster chromed angle exhaust tips on. If you can’t find the Flowmaster exhaust you could still go with the Delta Flow Series 50 mufflers.
zr1eddy is offline   Reply With Quote
Old 09-08-2018   #164
Crusin
Crusin's Avatar
It appears BB and Corsa are the two most used exhaust systems on ZR-1's. Wondering if Corsa has less drone than the BB? Thanks
Crusin is offline   Reply With Quote
Old 09-08-2018   #165
Bob Eyres
B&B (old style) is very loud with lots of drone.
Corsa cancels much of the drone, and as a high pitched shriek at top end.
It’s really very subjective, a matter of personal taste. I have Watson’s, no cats, X pipe, and 3” B&B’s deep and nasty.
"It's about the car, not the people."
1991 ZR-1 White/Black #1236 (Owner since 1994).
Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft.
Old 09-08-2018   #166
aafc
aafc's Avatar
I think my modified LT1 stock exhaust system is great . I removed my power effects system so i could install exhaust cut outs. Brought a used LT1 exhaust system,removed resonator made my own " H " pipe and added 3 in cut outs
just before the mufflers. I did not want the spare carrier so cut outs are in a good location. Switch on center consul opens or closes the cut outs a little or a hole lot . I'am running Jeal Headers. I'll be at Tony D's this Oct the 20th.
here is a pic. of my system.
1990 white/ black # 2546
one of a few auto ( 4l80E ) EQ. ZR-1's
aafc is offline   Reply With Quote
Old 09-10-2018   #167
Crusin
Crusin's Avatar
You did a great job on your exhaust, looks nice.
I think I will go with the Corsa less drone than BB Thanks
Old 09-14-2018   #168
Leroy1
I replaced the mufflers with 16" of chambered pipe; now have the C2 side pipe kind of sound except louder.
Leroy1 is offline   Reply With Quote
Old 09-14-2018   #169
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
I used ss tips and plain ss 3" pipe from the mid-pipe, and like you, I find it sounds loud and right!
Enjoy it!
Marty
Old 09-14-2018   #170
gtcollins@maxnet.co.nz
Hi here is my exhaust sound I have made my own heads 2" primary into 3" exhaust with X pipe 50 series flow masters muffler if you look at my you tube channel you can see my first start up and can see the exhaust system
https://youtu.be/vSDYWRKYcWc
Hope this helps
Regards Glen
Sent from my SM-G930F using ZR-1 Net Registry mobile app
