#161 |
![]() Join Date: Mar 2007
By the way....Jerrys intake bridge did not collapse...held up well
#162 | |
I'm assuming peak was 7100 which says u moved that up ~ 200rpm. Is this stock cams? |
#163 |
No these are the 222 .415 236 425 intake and 222 .415 exhaust cams
Peak was 7050 or 7100 on the run with 441rwhp Here is the dyno sheet(This is from the 2nd run) ![]()
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 08-03-2015 at 01:22 PM. |
#164 | |
![]() Join Date: Dec 2003
![]() Nice work on you concept and testing the results. Does look like you may have extended the power under the curve at the upper RPM range. That's useful!
#165 |
OK, so peak didn't change from Siamese ports. I was also comparing peak HP w mine since cams are similar. My peak is ~ 6900rpms w 36.5mm plenum port and head runners that neck down from 36.5mm at the top, down to about 34mm by the bowl.
#166 |
Went back to look at the last time I tuned my setup specifically, what happened at 7100rpm. HP was pretty flat losing 4hp between peak of 6850 and 7100rpm.
That seems to suggest little contribution from added plenum volume BUT the tune needs to be cleaned up before drawing any conclusions. Last edited by XfireZ51; 03-08-2024 at 02:10 PM. |
#167 |
#168 |
![]() Join Date: Dec 2012
Might as well, Lee.
Hellofa project you have taken on. Don't know that I would use cardboard tho..... Good Luck. |
#169 |
Thats called a template my friend
#170 |
Hmmmm.....what can I do with this thing? Any ideas?
