Old 08-17-2014   #161
Schrade
Default Re: OBX Headers?
Originally Posted by efnfast View Post
I did headers, exhaust, and chip upgrade. Went from 311 to 353 RWHP.
THat's a lotta' boost there Steve...
What's in the chip?
My second ship from Marc was only for 2nd deletion, I think. I could tell I was getting a little more twist; I'm guessing about 20 - 22? Maybe as much as 45 dB
Old 08-17-2014   #162
efnfast
What's in the chip?
Had a Mark H chip, sent it back to be modified for exhaust work. Recently dyno'd again at 397 RWHP.
Old 08-17-2014   #163
Schrade
Ok - this is interesting here...
I don't remember if I told him that I was doing new pipes.
Do I need to send it back to him? Anyone know if he keep logs of chip-work / chip ID's?
Old 08-17-2014   #164
KILLSHOTS
Did you send it to him after you installed your OBXs?
Old 08-17-2014   #165
efnfast
He also changes if you pull the cats out. Let him know.
Old 08-17-2014   #166
Schrade
No - he had it when I did the top end housecleanin', and it was for 2nd deletion. I said 'sometime' I would do the pipes, because he had asked about airflow mods.
I don't know if these psuedo-cats count for very much - I'm sure they're not for looks (or ARE they??? ), although Jeff [Shrek] wanted the new ones I got with the OBX, since he had given me his that were sewed up onto the X-section.................
I'll have to ring him soon here.
Old 08-17-2014   #167
KILLSHOTS
Yep, those bullets that come with the OBX are just for looks, they're not cats at all. I guess they're meant to help with a visual inspection in states where that matters.
You should definitely send the PROM back to Marc. When you do headers, he adds fuel to support them and enables the anti-backfire. Until you do this, you won't produce all the power that adding headers allows. Marc does keep excellent records; that's how he was able to figure out that he hadn't enabled anti-backfire on mine without even having it in his hands.
Old 08-17-2014   #168
efnfast
Glad the OBX came with the psuedo cats, in NH all we need is a visual inspection and the check engine light can't be on.
Old 08-17-2014   #169
Billy Mild
What kind of mods did you have?
Old 08-17-2014   #170
efnfast
Stock, as I got it. 311RWHP. 309 TRQ
Headers, exhaust,chip. 353RWHP. 341 TRQ
Ported plenum and Injector Housing (IH) 397RWHP. 363 TRQ
Next major upgrade will be head work and probably reground cams.
Welcome BTW.
