Closed Thread
Old 06-29-2017   #151
edram454
edram454's Avatar
Default Re: LED headlight upgrade
those are the lights I had on my zr1 before I sold it. these are fantastic and love the look. they are very bright but do not blind oncoming traffic. they have a very definite cut off. I miss these lights since they dont make them for c5's.
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
edram454 is offline
Old 06-29-2017   #152
yeah I am guessing the cutoff is due to the Projector for the low beam. I have projectors on my Charger, I like the cut off (but like the HID even more so)
-=Jeff=- is offline
Old 06-30-2017   #153
Locobob
Yeah they have a very defined horizontal cut off, I like them a lot
Robert
Locobob is offline
Old 06-30-2017   #154
efnfast
My new LED's do not have a cutoff like that, more like a flashlight. Mine were just replacement bulbs in a Hella housing.
efnfast is offline
Old 10-10-2017   #155
I just completed this upgrade last night on my 90 and damn I am impressed. I went with the same kit that locobob just installed and not only does it look agressive not on.... the amount of light it puts out LED wise is on the same quality as my wives new C300 Mercedes Coupe. You won't be disappointed. GC
GOLDCYLON is offline
Old 10-11-2017   #156
DITTOS... ^^^
I (back-ordered) those (Larsen) lights and opted for the load resistor instead of the relay splicing approach. (The current draw was NEVER an issue with the OE headlights, so amperage is not an issue, but everything working normally is!)
We'll see, once the stuff comes in...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Paul Workman is offline
Old 10-12-2017   #157
secondchance
DITTOS... ^^^
Paul,
I installed 3 pairs of these and the cleanest, simplest solution, posted about a year or two ago by a forum member, is to remove the fog light relay, identify the leg that plugs into ground socket, bend the leg around the relay housing, insert a electrical wire through a hole on the leg (for some reason they all have a hole), solder the wire to the leg, and finally find a ground point and ground it out. Works like a charm.
secondchance is offline
Old 10-12-2017   #158
Originally Posted by Locobob View Post
I recently converted to LED, been driving with them for a week or two now and pretty happy with the upgrade. They were plug and play except that I snipped and grounded the lt grn wire from the fog lamp relay - easy job and as a bonus the fogs stay on with the brights now. Here are some pics.
LED on left, low beams
Just a question. Is there really a point to having fogs ON w the HI Beams?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
XfireZ51 is offline
Old 10-12-2017   #159
Locobob.. those lights actually look pretty good. How is the pattern out on the road?
-=Jeff=- is offline
Old 10-12-2017   #160
Flyman 27
Flyman 27's Avatar
Locobob,
Where did you end up ordering them through?
Dan
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline
Closed Thread
