Old 07-26-2020   #141
Default Re: Ruff Idle ,Huge Loss of Power
Originally Posted by Tripler View Post
Shame the forum does not have a thumbs up option because I would really like to thumb up everyones posts . Extremely helpful . I have never heard of noids before lol but I see I can buy them here at our Canadian tire . On Monday I will check the ohm readings on the coils and attempt a test of injector electrical leads .
Thanks for that pic of the service module plug and coil ohm info
Thumbs Up
Sent from my SM-A205W using Tapatalk
Let me second the need for a Thumbs up or Like button. I have liked those on all the other forums; maybe this is another symptom of the aging vBulletin sites. Any way to add this feature to our existing forum site? --Bob
Old 07-26-2020   #142
Ccmano
Not a bad idea. I have put in a request. Keep in mind we are limited to forum capabilities which are out of our hands.
Of course you can simply use an emoji from the Selection to the right of the message box when you write the post.
H
Old 07-27-2020   #143
H
Thanks Hans. I realize some things are out of your control and some just can't be done with a specific platform. --Bob
Old 07-29-2020   #144
Tripler
Tripler's Avatar
Found 2 coils that have zero ohms readings and the other 2 work fine . Ordered 4 new from Corvette Depot .
There on back order so a few weeks to receive them .
Tripler is offline   Reply With Quote
Old 07-31-2020   #145
Tripler
Tripler's Avatar
Did the noid test . All primary injectors lit up .
[emoji106]
Old 07-31-2020   #146
Macroblock
Macroblock's Avatar
[emoji106]
Awesome - Great Job!
Macroblock is offline   Reply With Quote
Old 07-31-2020   #147
Tripler
Tripler's Avatar
Originally Posted by Macroblock View Post
Awesome - Great Job![emoji106]
Thanks Mac [emoji106] . Is there any other tests I need to do ?
Old 08-01-2020   #148
Macroblock
Macroblock's Avatar
Tripler - it sounds like you narrowed it down to an ignition issue. Once you replace the coils and reassemble the plenum, you'll be able to test.
Coils that are not providing adequate voltage are a sign of trouble and will cause the driveability issue you describe.
Old 08-01-2020   #149
Tripler
Tripler's Avatar
I am hoping that's all it is . I have replaced all the 25 year old bits that needed upgrades so far and I sure am looking forward to putting it back together . Again a huge thank you and thumbs up ...
[emoji106][emoji846]
Old 08-02-2020   #150
Macroblock
Macroblock's Avatar
No sweat. Let us know how you make out.
