Old 11-03-2013   #141
Schrade
Default Re: TOP END REFINISHING
INJ ret clips snapped into the G-spot x 8
Di-electric grease in the 2 IH D side forward connectors
Set the primary O's with a drop of Trans-X in the groove
torque down the IH
Old 11-03-2013   #142
Schrade
Polyglass / Gloss Red mix on the TB; 1st coat cured.
recipe for oil base can =
2 part polyglass resin HALF STRENGTH MEK HARDENER
... 5 drops MEK (as opposed to 10) per ounce polyglass resin ; you can go 4 drops, but cure time seems exponential as you reduce MEK
2 parts paint thinner
5 parts paint
The thinner mix allows laying flat; no brush strokes or sags. Half strength hardener allows longer working time, AND harder finish (increased cure time however)
You HAVE to use a quality paintbru$h from arts & crafts store. Cheapies lose bristles...
and you absolutely HAVE to allow TOTAL cure before second coat - second coat too early will prevent 1st coat cure vapors from escaping, and will cause bubbling / poor bond. Some say this is what happens in Detroit with peeled paint...
Old 11-03-2013   #143
Z06scentair
Z06scentair's Avatar
Shrade great job.....I'm near Charlotte Nc and planning on pulling the plenum on my car to fix a vacuum, oil, and antifreeze leak! Care to join
Z06scentair is offline   Reply With Quote
Old 11-03-2013   #144
Great job....and nice, clear, detailed large photos
I am referencing several posts in -Solutions- if for no other reason (but there are many reasons)...the clarity of the photos.
Will be interesting how the paint scheme looks once put back together
Old 11-04-2013   #145
Thumbs up Re: TOP END REFINISHING
THanks for specs there Franke; too lazy to grease up the FSM pages ATM, with grease - grub grease!
Half a yard bird, snap beans and 'taters, down in 5 minutes!
I know that's just what ya' wanted to see...
Moly grease, THIN film, both sides of coolant man gasket
set loose
torqued, with crossover elbow temp set
LOL this top end rebuild brought to you by our Sponsers BUD and BIRD!!!!!!
Old 11-04-2013   #146
Schrade
Jerry got those gaskets here pronto - thanks to him for that! And to Bill [geezer] (Owner's Manual), Steve [WeGone] (Z parts schematic CD), and ? [BearlyFlying] (TB shaft butterfly screws), and THAT list goes on..............
Thanks; but you sure you want MY hands on your car? I just screwed up 3 times last night - sunk the D side rail all nice and snug, WITHOUT the crossover in place . Then decided I'm not gonna' pull it til today, and decided to put in the D side coolant pipe in - dropping 2 clean greased bolts in the process . Re-clean THEM grrr. And then got it in, nice 'n torque'ed, withOUT polishing the end to bare metal .
Q: How many times can one screw up in an hour? A: How many tasks am I doing in that hour!
Quittin' time.....
Old 11-04-2013   #147
Quittin' time.....
Sounds like a very familiar path, but I trust to ultimate sucess --Bob
Old 11-04-2013   #148
Schrade
I'll take that in writing Sir - pen is on the windshield
So let's try again; the RIGHT way.
Pull the D side rail; oil the rail crossover D side inlet / outlet
fit (I don't know how far I thought I was gonna' go, with that screw in place - where's Houdini when ya' need him? ) AND KEEP YER GRUBBY FINGERS OFF OF THE CLEAN RAIL / INJ PORTS!
drive
clip
Old 11-04-2013   #149
Schrade
tighten clip
grease on rail holddown bolts
Will the same type connector in here, fit inside the CC vent crossover tube, if I cut the tube where I put the clamp?
Old 11-04-2013   #150
Franke
I don't think so as the CC tube is larger in inside diameter I think. Jerry's has a new CC pipe however its a bit pricey. I was thinking that maybe you could wiggle a slightly smaller PVC pipe or something similar through the hose up to the defect and then clamp it. Maybe not but I tend to analyze why parts like that fail since there isn't a lot of pressure etc on them. Got to be oil and heat breakdown or friction on a adjacent part. High temp RTV might work too if allowed to setup properly.
