Old 05-29-2014   #141
secondchance
Default Re: Secondchance - 380 build begins!
Originally Posted by QB93Z View Post
Yun, If the air horn doesn't make it in time, I will provide a loaner. No Worries!
Thanks Jim! I totally forgot about this one...
Old 06-01-2014   #142
secondchance
Saturday:
Arrival by Rich's truck.
Headers installed = all 28 bolts (later LT5s have 14 bolts per side).
Dropped under the hood.
Darrin in action!
Jim doing something...
Almost there!
As of 7 pm today, intake plenum/throttle body, camshaft sensor, PROM (borrowing a limp home chip while waiting for Marc's new chip to deal with secondary removal) and exhaust.
Hopefully she will start with no issue...
WAZOO gang and out of town visitors showed up Saturday and Sunday to help - what a group!!!
Also check out "LT5 installation" in the General section posted by Jim.
Old 06-03-2014   #143
secondchance
O.K. Since starting this thread on 7/18/2013 after concluding my head gasket had failed (actual failure happened on late April 2013) I declare my 380 project is 98% complete. I am expecting a PROM unit from Marc in 2-3 days and some fine tuning to continue.
I went up to Jim's garage yesterday and expected to wrap up in 2-3 hours. Boy, was I wrong. It took 7 hours of chasing some mundane problems to sort things out enough to turn the key. 380 LT5 started after about 3-4 seconds of cranking and came to life. Drove my Z around the block to make sure all vital signs are good and the car to be drivable before heading back to my home about 65 miles south of Jim's.
What a drive back home. To be able to drive without a fear of running my radiator dry AND running a brand new, bored and stroked (lightly) motor I actually helped build! It took a lot of restraint not to take her to the redline.
Just can't wait to put 500 miles, an oil change and take her out for a few revs to 7000 rpm!
Thank to all who actually made this possible and cheered me on. Now my Z is also a secondchance.
Old 06-03-2014   #144
When is the dyno scheduled! Congrats Yun!
Old 06-03-2014   #145
secondchance
Perhaps around 2,500-3,000 miles?
Thanks for your fine work and help!
Old 06-03-2014   #146
KILLSHOTS
Outstanding! Congrats on the new baby! Gonna be killer when she's broken in!!
Old 06-04-2014   #147
Racinfan83
Awesome story! Sounds like a great bunch of guys there - very cool how they all work together to get this done.
Old 06-04-2014   #148
Scrrem
Scrrem's Avatar
That's awesome Yun, I know you will be please with the outcome the first time you hit that 7,000 RPM mark!!
So, I guess you can now pick up where you left off with the brake upgrades
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 06-15-2014   #149
secondchance
Now that I have about 500 miles and fresh oil and vacuum leak is fixed (thanks Jerry for thicker gaskets!) I went out for a drive and stepped on it up to 6,500. What a rush!!! Ask me if I miss secondaries?! - a little bit. Use to feel like opening up secondaries on four barrel carbs...
Old 06-15-2014   #150
Do you miss your secondaries?
