#141 |
when a coil goes bad does it allways effect both cylinders or can it only effect 1 cylinder ???/
#142 |
![]() Join Date: Jan 2009
Both if it is the coil. My latest experience was with a single plug (#3) so I knew it was not the coil.
#143 |
#144 | |
#145 | |
Greg, more than likely your injectors were sketchy anyways. If the coils do solve the problem, your car will run pretty sweet. I still stand by my suggestion of pulling the plug boot off while the motor is running. A strong coil will have an audible pop to it. A weak coil will not arc at all. http://www.zr1netregistry.com/forum/...ead.php?t=4667 |
#146 |
Jeffvette ='s Nice guy and great American
#147 |
![]() ![]() Join Date: Mar 2006
Greg, here's a thought
drive it to, M. Haibecks in chicago and fly home. another thought, contact Corey Henderson he will be in Oklahoma for the gathering in sept. i'd offer to drive it to haibecks from the st louis area, going up there to pick mine up, in a couple of weeks. if you are pressed for time. good luck Keith |
#148 | |
I'd sure like to get a hold of one that fails on just one side. You may have not seen the failure but I wonder if it wasn't still failing? Or maybe one of the two ignition wires was arcing to ground. Each of the four coils fire on two plugs at the same time. Once on compression and once on exhaust stroke. If one plug is very fouled it may not show spark at all and the other will. Next time you see what you think is "one tower" fireing. Try unplugging both sides and place a known good plug in each and ground the outside of each plug. The spark on each should be the same even if the coil is failing. The trick is to compare a good coil to a bad one. Depending on how bad the coil is you'll see a marked difference. Best check I've seen on the net was measuring the secondary coild resistance when the coil is hot. With wires disconnected it will be about 5.7 ohms acording to my notes.
#149 |
I've stumbled on it twice. Spark is nice and strong on one side, and weak or non existent on the other side. Not sure if it's corrosion issues inside the tower. Next time I get one I'll save it for you to dissect.
Greg, any update? |
#150 |
Just got the coils in Monday. If I can find some time this weekend, I'll change them. Time is the problem though.
