#131 | |
If connecting 5 and 8 didn't have any affect, it's pointing to an ignition problem. Perhaps a coil or the Ignition Module (DIS). Sounds like you'll need to pull the plenum to test and repair further. With the plenum off you can test the ECM (-) outputs to the injectors. A couple of noid ("solonoid") lights will come in handy for this. A basic 12v test light will be needed to simulate a Crank Hi signal to spoof the Ignition Module and ECM. Let us know when you have the plenum off. |
#132 |
![]() Join Date: Nov 2007
5 & 8 are the same coil... seems like that might be the problem
#133 | |
![]() Join Date: Apr 2013
I fully expected to pull the plenum again . Will keep you updated . ;-) |
#134 |
#135 |
You can take a look at my thread on chasing knock. If u go here, you can see what you may want to check for regarding ur coils.
http://www.zr1.net/forum/showpost.ph...8&postcount=16 |
#136 | |
Since the coils are 25+ years old I will switch those out first with new wires and plugs . If it still idles ruff and has no power then back to checking more bits . I will need a bit of instruction on how to test the injector cables to make sure they are putting the right amount of voltage to the injector . Thanks Sent from my SM-A205W using Tapatalk |
#137 |
I got the plenum off again . What are the steps to test the Coils .
#138 | |
The coils are all the same so if you want to test for the sake of testing you could exchange the coil that serves 5 and 8 with another coil and see if this moves the symptom to another cylinder pair. If the problem moves, it's likely the coil but if it remains on 5 and 8, the problem could be a bad hi-tension lead or leads, bad plug or plugs or an issue with the Ignition Module. ----------------- To test the ECM and injectors with the plenum off you will require a test light and at least one 'noid' light. Put the key to "ON". Connect the test light alligator clip to the battery (+) and quickly and repeatedly connect and disconnect the probe end to the Crankshaft HIGH pin on the Ignition Module Test Port. Pulsing a signal to the Crankshaft High line will spoof the ECM into thinking you are making a start attempt (i.e. <400 RPM). You will notice the fuel pumps come to life and a few other devices. All primary injectors will fire at the same time. Now disconnect all the primary injectors. Put a 'noid' light on each injector connector or do one connector at a time if you only have one 'noid'. Spoof the ECM again and verify that each primary circuit lights up the noid. Note 1 - The ECM output to each injector is (-). Note 2 - If you don't have a 'noid' light a test light can be substituted. Note 3 - Link to image of Ignition Module Test Port: http://www.zr1ecm.com/img/blog/detai..._TEST_PORT.jpg ![]() Last edited by Macroblock; 07-26-2020 at 01:08 AM. |
#139 |
#140 |
Shame the forum does not have a thumbs up option because I would really like to thumb up everyones posts . Extremely helpful . I have never heard of noids before lol but I see I can buy them here at our Canadian tire . On Monday I will check the ohm readings on the coils and attempt a test of injector electrical leads .
Thanks for that pic of the service module plug and coil ohm info Thumbs Up Sent from my SM-A205W using Tapatalk |
