Closed Thread
Old 02-09-2017   #131
G8nightman
G8nightman's Avatar
Default Re: LED headlight upgrade
Got mine installed last night works great. Alot easier then messing with the grounds on the car.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline
Old 02-09-2017   #132
is that sliver box the resistor?
-=Jeff=- is offline
Old 02-09-2017   #133
Jeff,
Doesn't the resistor simply substitute for the load a standard headlamp puts on the electrical system? if so, why would it be detrimental or an issue?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
XfireZ51 is offline
Old 02-09-2017   #134
steve1263
That is exactly what it does. When I was installing the led headlights on my car I turned on the lights after the first one was in and found everything working properly including the fog lights. when I installed the second light and tested everything I noticed the fog light problem. The resistor is advertised as a fix for the bulb out problem some cars experience when converting to leds. Both problems are addressed by simulating the load of an normal bulb, thats why you only need one.
[SIGPIC][/SIGPIC]
steve1263 is offline
Old 02-09-2017   #135
G8nightman
G8nightman's Avatar
Yes sir
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 02-09-2017   #136
That's easy to zip tie. I had to do the same with my Ballasts for my HID projectors on my 91
GOLDCYLON is offline
Old 02-09-2017   #137
Roadster
Roadster's Avatar
As posted in #105, don't know how to do the arrow thing to point out in the pic...but take notice of the plastic ties I used, fits up very nicely in the top of the housing, and it's secure...
Resistor tucked up nice and secure...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Roadster is offline
Old 02-09-2017   #138
Jeff,
You are correct and there is no issue with it..
I just would change to the relay to make it less than the OEM load.. that is all
-=Jeff=- is offline
Old 02-09-2017   #139
Roadster
Roadster's Avatar
Again just curious, if it isn't such an issue with the resistor, then why bother with the relay? Is it that much of a load difference??? The resistor is a breeze to install, compared to adding another relay and cutting or connecting into a wire harness which would take more time....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Roadster is offline
Old 02-09-2017   #140
G8nightman
G8nightman's Avatar
Yes I did the same with mine fits like a glove
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Closed Thread
