Old 02-17-2014   #131
Kevin
Kevin's Avatar
Default Re: Corvette Museum
Originally Posted by Tripler View Post
Do you have the link ? I never found it
https://www.youtube.com/watch?v=W5FG9_mGWPo
Old 02-17-2014   #132
Tripler
Tripler's Avatar
Wink Re: Corvette Museum
Originally Posted by Kevin View Post
Ok ,,, Thanks ,,, . Looks like I saw that already . I thought it was with another one from a different mini chopper .
Tripler is offline   Reply With Quote
Old 02-17-2014   #133
Wonder if the museum itself has sinkhole coverage for the building....earth movement is excluded under most base policies. I am not referring to the cars but the building structure.
I believe they are saying now that this is not a covered loss.....
Old 02-17-2014   #134
#‎Corvette‬ owners! Show your support of the National Corvette Museum by changing your FB avatar and sharing this status!
If you can, please donate at www.corvettemuseum.org as we are going to be faced with a deductible and a large expense of sinkhole repair/mitigation that is not covered by insurance.
Thank you!!
Old 02-17-2014   #135
Its not clear if its saying the building is not covered or just the sinkhole mitigation(they mention a large deductible indicating there is coverage for something).
Generaly is the sinkhole damage is covered to the building so is the grouting and sinkhole mitigation
Old 02-17-2014   #136
Fully Vetted
Fully Vetted's Avatar
So, how does this affect the Gathering itinerary, if at all? We are in effect 12 weeks out. I'm sure they will have done their studies to determine if the rest of the structure is in danger but there's no way they will have it repaired by then. Other than moving the banquet maybe it won't affect us at all.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 02-17-2014   #137
RHanselman
RHanselman's Avatar
As of now we are still on. We also are working backups just in case.
Cheers,
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 02-17-2014   #138
USAZR1
USAZR1's Avatar
Has the NCM re-opened yet?
Old 02-18-2014   #139
Yes I believe it opened the following day last I read
Old 02-18-2014   #140
taximan
Its a covered loss. However, the cost of reinforcing the spire, and other necessary update costs are not covered. I am sure the NCM would appreciate donations to replace those funds.
taximan is offline   Reply With Quote
