#131 | |
#132 | |
![]() Join Date: May 2010
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#133 |
Ricky and Craig, I saw your post regarding the Van Steel coilovers. I am not familiar with that setup but I can tell you that the success and satisfaction you will get with the DRM coilovers will be hard to beat. I would have to say that the DRM would be the preferred set for several reasons. 1.) With all the help available on this forum from an installation standpoint, it would be wise to consider the DRM's as a first choice as installation can be a bit challenging. 2.) performance: DRM's set has been used countless times on C4s from the race track ( Corvette Challenge, World Challenge, high dollar tuner cars,Lingenfelter, etc.) with great success. 3) Randy @ DRM is a great guy to work with. 4.) I can personally add that I have had this setup as well as one of my best friends on our race cars for over 10 years with zero issues. We have raced with SCCA, NASA, COMSCC & NCCCC with excellent results. Many race wins, FTD's between the two of us. Even though I am having some moments with this latest install, I can tell you that when you guys are ready to do yours I could definately help out with a few tips that will make your installation MUCH easier. I am not one for re-inventing the wheel and I would highly recommend DRM as the preferred kit. My friends and I have worked with Randy at DRM with our race cars for over 10 years and you could not ask for a nicer guy.
#134 | |
Thanks, will be reaching out to you in the new year. Keep us posted on your front set up when you start. |
#135 |
Ricky, I owe you one for hooking me up with center caps. Don't think I forgot all of your help. I think by the time this installation is over I can save you a lot of time by not making the mistakes I have. JUst allow some down time as this is NOT a quick turnaround. Hope you have a great NEW YEAR. Hopefully this year I can get out a little more and have some fun with the Z after all of this work. I will keep you posted when I start on the front.
#136 | |
Thanks brother, have a safe & happy New Year! We'll touch base, I trust your call on this setup so looking forward to it. |
#137 |
Well. I know it has been awhile since this all got started but I was able get all of the coilovers mounted on saturday. Now I have to say that there are some challenges taking out the front spring and I am glad it is done. Something I would not look forward to doing again. One thing many might find interesting. I had removed the front spring once before to install the poly shims that are available through Mid America/ Ecklers along with the lowering bolts. The poor mans suspension adjustment setup. When I removed the front spring this time, I had found that the poly lowering wedges were absolutely destroyed. There was nothing left. That is after about 1500 miles of pretty easy driving. So in other words, that stuff is JUNK. The coilovers are on and this morning spent some time adjust the front ride height. Getting close. I'm burnt out now so the rear will have to wait for a day or two. The service ride control light is now on so I will also have to look into that. When I am finished, I plan on putting together some do'd and don'ts for the this coilover install and hopefully it will make anyone who wants to do this conversion aware of certain issues that can be avoided for an easier install. Thanks for everyones help on the forum who responded to my many questions. Pictures will follow one day.
#138 | |
![]() Join Date: Aug 2006
#139 | |
What are your and the group's thought about non FX3 if going coilovers and just get rid of the FX3? I don't know if any installation benefit or just avoiding future problems and cost. Thanks for sharing. Craig
#140 | |
I am seriously thinking about going coil-over come spring. I intend to keep FX3, if anything, to keep the SRC switch working. If I elect to discard the system later that can be done regardless. In 18 years of ZR-1s, 1991-1996 and 2000-2013, FX3 functioned 98% of the time without any issues. So, why discard it? |
