#131 | |
![]() Join Date: Jul 2005
I do love those CAM'd up motors and the smell of high octane!
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int Last edited by RHanselman; 05-15-2013 at 08:37 AM. |
#132 |
That is a sweet 427 LT5 you have there! congrats
#133 |
![]() Join Date: Aug 2005
Some work to do this weekend... 30lb Ford Motorsports injectors. These are Bosch Design III's and are actually 35 lbs/hr at our rail pressure. That should be sufficient.
![]() And the best part is, I have the full injector dynamic characterization for these. Expecting it will improve the light load operation significantly. A nearly new set of Lucas 26 lb'ers are for sale, if anyone is interested. ![]() |
#134 |
"And the best part is, I have the full injector dynamic characterization for these. Expecting it will improve the light load operation significantly."
Nice to know that. Not sure what the problem is w ACCEL in providing that information. Everyone else has it available. |
#135 |
All back together and running good. This is enough injector to support 900 hp so should be sufficient
![]() Also found out the valve stem seals aren't sealing that well, had some oil behind the intake valves. At least now I know it's not getting in past the rings. So add to the list for upgrades next time the motor comes out. |
#136 | |
use the F*rd injectors. I can give you the offsets. Todd |
#137 |
So I am gathering some ideas for a presentation on this engine at BG this year. Help me get started... what would you guys like to know more about? Trying to make it different/more detailed than the HOTB article I did 3 years ago.
I plan to spend most of the time on the induction system, since that is where the power is made. What else? |
#138 | |
As I recall you also spent a great deal on the valve train and nailing down the cam spec. As Vizard has demonstrated, matching the cam profile w the cylinder head flow is key to making power. I'd be interested in hearing how you went about that and the development of your objectives for the motor. How did that all play into finalizing the configuration you now have. As a sidebar, what challenges did you encounter on tuning this beast? Totally unrelated, you really need to bring that baby up here for the 1/2 mile in Monee. Just asking. ![]() |
#139 | |
![]() Join Date: Nov 2007
![]() ![]() Quote:
Paul. PS: YEAH...WHAT DOMINIC SAID!! Some shmarty pants LS7 loud mouths need a lesson in DOHC! ![]() Last edited by Paul Workman; 02-26-2014 at 09:58 AM. |
#140 |
I'd like to see this beast on a quartermile
Sam |
