10-02-2020 | #131 |
Re: Poll: Who has ever hit the rev limiter?
I treasure my car.
I baby the car. I LOVE my ZR-1! That said; If you are not, on occasion,bumping into the rev-limiter, then either let someone else drive it if you really cannot bring yourself to do it and witness that the sky will not fall. OR Play a little more aggressively with it each time until you do. Few things in life are as much FUN as DRIVING a C-4 ZR-1. Any car revs to 5,000. 6,000 still quite a few. 7,000 not many Aim for 7,500 by holding off until you see the needle pass through 7,000. At the rate age is slowing me down, I may have to soon start the shift at 6,000 to hit 7,500 When young, I left on the last yellow light. Today I could almost start one second after the stage light glows. Ahhhh, the golden years!!!!!!!!!!!!!!!!! ENJOY IT WHILE YOU CAN! Go for 7,500!!! Marty |
10-03-2020 | #132 |
ZR-1 tachometers are notoriously inaccurate due to the IC within the instrument panel cracking and changing resistance due to age, heat and vibration. Batee.com sell a 90-96 Tach Fix 8000rpm kit for remedying this problem. In order to verify the accuracy of the tach, plug in a Tech 1 or ALDLDroid or similar.
Richard 1990, numbers 1821 and 2391 1821 - owned since Nov 2002, charcoal / Gray, Stainless headers, B&B system, 4.10's 2391 - owned since Jan 2019, Black / Black, have completed restoration. Jeal headers, Corsa system, 4.10's, Aluminum flywheel with Carolina clutch. |
10-17-2020 | #133 | |
10-19-2020 | #134 |
After I finished calibrating the tach and doing my "510" porting (& Marc Haibeck tuning), I'd hit the rev limiter in 3rd gear about 100 yards BEFORE crossing the 1/4 mile trap. Marc Haibeck had to bump my limiter to 7500 to solve the "problem". I don't hit the rev limiter very often now tho. (I'm good for 121 mph in the traps now, in 3rd gear.
You can see from the 3.45 gear chart where the (7100 rpm) rev limiter would be a hindrance when trap speed of 121 in 3rd gear was in play... Oh! And if you haven't tried the "510" package, you don't know what your missing!!! Edit: Update: Nearly 1/3 of Z owners have never "let the BEAST out of the cave"! Shame on you!
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 10-19-2020 at 09:33 AM. |
10-23-2020 | #135 |
Hit the limiter on the back straight at the Corvette Museum Motorsports Track. Then I had to slam on the binders to turn. It was glorious!
Sent from my SM-G955U using ZR-1 Net Registry mobile app |
11-05-2020 | #136 |
If you've never hit the rev limiter, you're not driving it hard enough!
Having said that, once I put a Raptor shift light in mine, I never hit the rev limiter anymore and I run my car to the shift light every time I drive it. My rev limiter is 7400, and my shift light is set at 7300. The shift light is in the AC vent pointed right at my eye and as soon as it lights, it's an instant reaction to shift (don't actively think about it, it's muscle memory and subconscious reaction). I've spend a LOT of money on this car, and the shift light was the best mod I did to it.
Evan
2024 Z06 SOLD - 1991 Admiral Blue ZR-1 SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP SOLD - Steel Blue 91 391cid ZR-1 #391 SOLD - Black 91 ZR-1 |
11-05-2020 | #137 | |
11-05-2020 | #138 |
What is the rev limit on a Z? Honestly, I've never noticed on a hard run. I know I've hit it because the engine is saying that's all I got, time to shift.....But never been looking at the tach at time of shift to see exactly.
11-05-2020 | #139 |
Guess I should have clarified, I'm running a 391 with stage 2 cams. The power does NOT drop off.
Evan
11-05-2020 | #140 |
