View Poll Results: LT5 Powder Coating: What color?
LT5 Grey 71 36.04%
Competition Yellow 7 3.55%
Arctic White 7 3.55%
Torch Red 17 8.63%
Cyber Grey 4 2.03%
Black 15 7.61%
Black Crinkle Finish 8 4.06%
Metallic Silver 68 34.52%
Voters: 197. You may not vote on this poll
Old 05-06-2021   #131
Default Re: What's your color choice for LT5s?
Originally Posted by dredgeguy View Post
Thanks Matt, my thoughts are that every engine I have seen touched by Marc looks amazing. I cannot see how that would hurt the value unless one is going for NCRS and even at that, do not think you would take a huge hit on points.
I absolutely agree with your assessment on Marc's work. While I did not go for NCRS certification with my dearly departed '95 I did think someone might want to after my ownership. That is why I had Marc do my engine with the Fine Silver color which Marc said was a close as he could get to stock. I also had him reuse the stock black bolts and studs to make it look as stock as possible. As to the "Haibeck 350 510 HP" lettering, it is done with stick on decals so they are removable. Sad that I have not seen my car since I sold it in 2016 but maybe if we get some car shows going it will pop up, as it was sold in the Chicago area.--Bob
Old 05-06-2021   #132
JSad
JSad's Avatar
That looks great with the Fine Silver. This winter project for me is a deep clean and detail of the engine bay and front suspension. I may consider painting the engine if the clean and detail don't result in the look I want.
JSad is offline   Reply With Quote
Old 06-06-2021   #133
Bob Eyres
I?d like to take advantage of the uniqueness of all those aluminum castings on the LT5 by removing the paint entirely.
Has anyone here ever seen one that was blasted with media and clear coated without yellowing?
"It's about the car, not the people."
1991 ZR-1 White/Black #1236 (Owner since 1994).
Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft.
Old 06-06-2021   #134
gtcollins@maxnet.co.nz
Hi my engine is clear coated and hasn't yellowed I don't think it gets hot enough to yellow I base coated and clear coated my brake calipers and the clear coat went a golden color after racing the car and the brakes were burning the rubber boots on my C6 calipers the first photo is no yellowing with nominal driving the second photo is after a day's racing and the last photo is after another day's racing with very heavy braking and the engine oil temperature was just under the to hot color section on the gauge and the clear coat on the engine is still good no yellowing hope this helps 20190717_231403.jpg20190922_074551.jpg20210510_170624.jpg
Sent from my SM-T865 using ZR-1 Net Registry mobile app
Old 07-03-2023   #135
dredgeguy
dredgeguy's Avatar
Bob, after Marc polished my engine we sprayed Gibbs Penetrating Oil onto a microfiber and wiped it on the polished engine. After about 30 seconds wipe it off with a clean microfiber and you are done. It seals up the pores, no added polishing needed and no oxidation. I have done nothing to mine for almost 5 years other than maybe wipe down with a damp microfiber if dusty after a car show with the hood open all day. Bob Lambe told me about Gibbs as he used it on his polished engine and after seeing his, had to do mine!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 07-03-2023   #136
JT ZR-Won
I'm gonna have to vote red
JT ZR-Won is offline   Reply With Quote
Old 08-23-2023   #137
Jagdpanzer
Jagdpanzer's Avatar
I went with a good quality anodized silver powder coat.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
