Old 11-01-2008   #121
Default Re: LT5 Assembly Project
All the piston are out:
Piston 1 bearings:
Old 11-01-2008   #122
Piston 2 Bearings:
Old 11-01-2008   #123
Piston 3
Old 11-01-2008   #124
Piston 4
Old 11-01-2008   #125
Piston 5
Old 11-01-2008   #126
Piston 6
Old 11-01-2008   #127
piston 7
Old 11-01-2008   #128
piston 8
Old 11-01-2008   #129
Also took the timing chain, upper gear off....
before:
Removal is striaght forward. Loosen the 2 small 8mm bolts on the tensioner to the lower left(main timing chain), loosen the three upper gear bolts, alittle maniplation and its off. Note for reassembly the three bolts are not symetrical, one is offset.
Also not in the top picture that the gear is offset to the passneger side, and the chains are not the same length to compensate.
After:
Upper Gear:
Old 11-01-2008   #130
Here is a pic of the tensioner arms, on the top is a plasitic rub strip. Two of these are damaged(rub strip)....
I believe DRM has these for $30 per
92 ZR1
#234
