Closed Thread
Old 02-07-2017   #121
Roadster
Roadster's Avatar
Default Re: LED headlight upgrade
All this talking about the headlights and I couldn't stand it any longer. Hooked up the battery and guess what.......they work, and they are bright.
I will also confirm that the fog lights work too with only one resistor..
bright lights... fuzzy pic....lol trying to get the pic before the lights flipped up....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Roadster is offline
Old 02-07-2017   #122
I think another relay at wired near the current Relay will accomplish the same thing as the resistors, but eliminates the load of the resistors on the electrical system..
One added relay:
Cut Lt Grn on Fog light relay
Harness side of Lt Grn to Pin 86 of new Relay
Pin 85 and Pin 30 of relay to Ground (New Wire)
fog light side of LT Grn to 87a.
-=Jeff=- is offline
Old 02-07-2017   #123
One added relay:
OK Jeff. We can do that when I install mine.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
XfireZ51 is offline
Old 02-08-2017   #124
Maybe, that relay is under the dash on the pass side I believe
-=Jeff=- is offline
Old 02-08-2017   #125
You doing yours too -=JEFF=- ?
GOLDCYLON is offline
Old 02-08-2017   #126
no, but when a user posted this on CF, and even posted here, I thought about their fixes and looked at a couple schematics and came up with my solution.
I am planning on doing that relay change to my car, even though I I still run H4s. I need to check the FSM again to confirm my idea will work, but it should
-=Jeff=- is offline
Old 02-08-2017   #127
Well you are an electrical guy so I get that. However I thought for sure you would be all over this mod as well
Old 02-08-2017   #128
Roadster
Roadster's Avatar
One added relay:
Jeff, can you explain further on your statement..."Relay will accomplish the same thing as the resistors, but eliminates the load of the resistors on the electrical system.."
Always willing to learn something new, especially electrical....
Thanks...appreciated...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Roadster is offline
Old 02-08-2017   #129
It is on my list. Just lower priority at the moment
-=Jeff=- is offline
Old 02-08-2017   #130
Roadster
Roadster's Avatar
Sounds good to me, whenever you get time....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Roadster is offline
Closed Thread
