Congratulations Greg!!
The entire ZR-1 brotherhood applauds you! Your perseverance, determination, and resourcefulness have finally paid off. 34 months, 173 posts, 8,600 looks later and the problem is now solved ....and at the end you got it right about the coils. I almost picked up a set of Accels a while back for spares but went with the MSD 8224's instead. Just checked them and they meg out the same as your new set of GM D545's. Last edited by Jagdpanzer; 03-22-2009 at 06:54 PM. |
#2 | |
![]() Join Date: Feb 2006
Is the LT5 coil a common GM part?
I may have figured out the difference between the GM D545 vs the GM D555 coil. The D545 lists for 70 cents more than the D555. It looks like the D545 comes with a little rubber gasket a hair over an inch long that goes around the 2 pin connectors under the coil. From best I can tell, the D555 comes without the rubber gasket.
Damn awesome !! Makes me feel better I changed out mine with GM replacements as well when I had the top end done. Damn gald to hear you chased that problem down!! I considered going the Summit route as well
Good Job Greg!
![]() I commend you for your perseverance. ![]() I personally would have given up hope after only a month or two, but you've hung in there for nearly 3 long years. Simply Amazing. Now, get in it and..... DRIVE IT LIKE YOU STOLE IT!!! Congratulations, my hat is off to you. Long live the beast. TomC "Crabs" |
#9 |
![]() Join Date: Dec 2004
Good deal Greg!
![]() You wouldn't happen to have the part number for the GM coils? TIA ![]() Tom
