#111 |
My wife's 1991 #1840 now has 80k miles.
Appears to be stock injectors, I've only used Sunoco or Mobil 93 since we bought it at 75k. Only real issues have had to do with prior owner. Trans has shift fork and syncro issues, bought it this way. Emissions problem with gutted cats, elec problems from DVD stereo, that sort of stuff. About due for hoses, clutch, lower control arm bushings. The bushings are because of the slicks I'm sure. Couple of trim bits, weatherstrip, no big deal. Cheers, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
#112 |
Mine has 42k,some minor issues but I think Marks chip will cure them.
#113 |
![]() Join Date: Aug 2012
19,500 miles.. New accel injectors, A/C conversion, weak headlight actuator motor replaced, four speakers and tape unit reman, exhaust system removed, reanodized, replaced, leaky driver side header stud repaired, clutch slave r/r.,secondary fuel pump replaced, Marc chip.
#114 |
![]() Join Date: Jan 2004
1995 ZR-1, Lingenfelter 390 LSV, only issues are I had the secondary switch selenoid fail and decided to pull the secondaries out, and had a new clutch roast at BG.
car pulls like a freight train, consistently dynos at 508 at the tires or higher. LPE build it back in 97 with 13k miles, so I have 67k worth of grins on the stroker. the LT5 is one tough hombre, and the LPE builds only enhance that. probably the most durable and trouble free high performance car I've ever had, and I have a few. I take it to redline often at 7400 (limiter at 7500) and the car responds consistently when driven hard and often. been commuting to work in it this summer during decent weather with the top off and the targa truss in place. even with the high price of gas, it's SOOOOO worth it. life is too short to drive junk, and I value time in the Z immensely I fully intend to "wear this one out" and chances are good it will outlast me!!
#115 |
Oldest thread ever?
Regards |
#116 |
Ok; I'll go 117th
![]() '90. 32k...
#117 |
My 92 #246 has 68,000 miles
New injectors, wires, coil packs when I purchased it last year at 62,000 miles. Since that time, minor issues, back up light switch, headlight bushings, one FX gear, air pump for seat and amps. Lucky to live in Wazoo land with talent willing to help anytime. Car runs strong and looks like new.
#118 |
![]() Join Date: Mar 2012
1990 #862. I have 28500. Third owner. Bought it in 09 with 19k. Just put new injectors/coil packs/fuel pumps/plugs and wires. Runs like a champ. Looks like new! Replaced brake light switch and oil pressure sensor a few years ago. New tires. No other Mods. But like Charlie, I'm glad to be living in WAZOO country.
Wayne
Wayne 1990 #862 Red/Red Haibeck Chip B&B cat back |
#119 |
254,000 miles
#120 |
1990 Charcoal Metallic #1217 @ 53,455 runs great, but working on recent secondary vacuum system failure.
[SIGPIC][/SIGPIC] |
