View Poll Results: Which oil do you use?
Amsoil 79 22.13%
Castrol 19 5.32%
Champion 0 0%
Chevron 0 0%
Conoco 0 0%
Citgo 0 0%
Havoline 1 0.28%
Interstate 0 0%
Kendall 1 0.28%
Lowe 0 0%
Marathon 0 0%
Mobil 1 224 62.75%
Motorcraft 0 0%
National 0 0%
PennZoil 4 1.12%
Quaker State 3 0.84%
Redline 10 2.80%
Royal Purple 11 3.08%
Valvoline 5 1.40%
Voters: 357. You may not vote on this poll
Old 10-20-2014   #111
Toni94ZR1
Toni94ZR1's Avatar
Default Re: Which oil do you use
Here in Barcelona (Spain) we use in our ZR1:
Mobil 1 5W50 Peak Life
API SN / SM / SL
ACEA A3/B3, A3/B4
API CF
Mobil 1 5W50 Peak Life aproval:
VW 501 01/505 00
PORSCHE A40
MB-Approval 229.1 / 229.3
BMW High Performance Diesel
Lexus LFA Factory Complete
Specifications:
Valor Viscosidad, cSt ASTM D445
@ 40 º C 108
@ 100 º C 17,5
Índice de viscosidad 180
Sulfatada Ceniza,% en peso (ASTM D874) 1.3
El fósforo,% en peso (ASTM D4951) 0.1
Punto de inflamación, º C (ASTM D92) 231
Density@15.6 º C g / ml, (ASTM D4052) 0,85
Número Total de Base (ASTM D2896) 11,8
MRV a -35 º C, CP (ASTM D4684) 29.244
Viscosidad HTHS, mPa • s @ 150 º C (ASTM D4683) 4.4
Toni Pujol
1994 Black on Black ZR1 #080
my brother is Ramon (93ZR1Barcelona)
1993 Black on Light Grey ZR1 #317
Want to belong to 500+ HP ZR1 club
350 Engine ready to assemble.
Full porting done (Heads, IH, Plenum,TB63, Air Horn)
Pete reground cams.
Fidanza
Borla+SW Heders+SW Xpipe
C5 Z06 front Brakes
DeWitts Radiator
Home made shrowd + 2 speed Motorcraft single fan.
Mopar 4.10 pinion & ring
Toni94ZR1 is offline   Reply With Quote
Old 05-05-2015   #112
HAWAIIZR-1's Avatar
API SN / SM / SL
ACEA A3/B3, A3/B4
API CF
VW 501 01/505 00
PORSCHE A40
Specifications:
@ 40 º C 108
@ 100 º C 17,5
Hello Toni,
Sound good. I don't think we have that Mobil1 in the US. What kind of PPM does it have for phosphorous and zinc?
When are you and your brother coming out to C4/ZR-1 Gathering at BG again?
Take care and Aloha,
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 05-07-2015   #113
Hib Halverson
Wow!
Those pole results...
A stunning endorsement of ExxonMobil's marketing of the "Mobil 1" brand.
In fact, that the three highest poling engine oils all come from companies which market very aggressively speaks volumes about how oil companies market products and what consumers believe about oil company advertising.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 05-07-2015   #114
Hib Halverson
Hello Toni,
According to what was posted previously, the M1 5W50 available in Spain is an API SL-rated oil BUT, is exempt from the ZDDP limits in that category because it's a 50-wt. According to ExxonMobil information I have on file, zinc is 1000 ppm and phosphorous is 1200 ppm.
Keep in mind that no LT5 needs an SAE 50 engine oil unless the duty cycle is severe in very hot weather. For normal street use and even street high-performance use, I would not recommend a 5W50 in an LT5.
Also, LT5s are OHC engines with direct acting bucket tappets. The loading on the camshaft lobes and lifter faces are far less in an OHC valve train than they are in a pushrod valve train, thus, there is no need for high levels of ZDDP.
Hib Halverson
Technical Writer
Old 05-07-2015   #115
Mr Blue
Wow!
It's more than advertising. The widespread availability and subsequent lower price also account for the predominance of the Mobil 1 brand. Also, having a Mobil 1 placard under the hood helps. Name recognition and being the first to market synthetic on a large scale don't hurt either. You are correct that marketing is a big driver of our choices. Amsoil is marketed as a " craft oil" to those who don't like the thought of a mass produced product in their pride and joy. Do they fill a niche in the market? Yes. Do they do more or better research the Mobil or Castrol? Probably not. Things that that make you say hmmmm.
Mr Blue is offline   Reply With Quote
Old 05-07-2015   #116
Mr Blue
Wow!
Old 05-08-2015   #117
BigJohn
BigJohn's Avatar
Wow! Now I am seeing double.
Old 05-08-2015   #118
Mystic ZR-1
Mystic ZR-1's Avatar
How's things in Hoosier-land?
Old 05-08-2015   #119
BigJohn
BigJohn's Avatar
80 degree afternoons and sunny. The GTX has a gas tank leak. But that is part of owning antique cars!
Old 08-10-2015   #120
The Truth About Zinc & Motor Oil
http://www.drivenracingoil.com/news/...-in-motor-oil/
Zinc Versus Detergent In Motor Oil
http://www.drivenracingoil.com/news/...-vs-detergent/
[IMG]http://i119.photobucket.com/albums/o128/wb9mcw/SIG-2.jpg[/IMG]
[IMG]http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif[/IMG]
[FONT="System"][SIZE="3"]"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln[/SIZE][/FONT]
