#111 |
![]() Join Date: Dec 2003
Graham has it up on Facebook. I revised the link above to show the video there.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 03-21-2019 at 09:38 PM. |
#112 |
#113 |
![]() Join Date: Aug 2015
Stellar stuff guys!! Thanks for the persistence and innovation!
Sent from my SM-G950U using ZR-1 Net Registry mobile app |
#114 |
Excellent!! And a dramatic presentation!! Congrats!!
Roger 1990 ZR-1 #2699 Black on Black 15,000 miles Full-time secondaries, 4.10 gears, C-beam plates, ported top end |
#115 |
![]() Join Date: Jul 2007
Saw the video on the registry’s Facebook page.
What are the next steps?
#116 |
![]() Join Date: Nov 2007
Congratz on a significant milestone! Packaging/cooling, duration, and temperature cycling tests to follow, I presume. But, this is one of the most significant breakthroughs for our cars in some time! This ONE item may have a truly significant impact on market value of our cars too! "Keep the Legend Alive!"
#117 |
![]() Join Date: Feb 2013
There are many steps to complete in the process of validating the hardware and software going forward. The video shows what actually is a pretty significant stress test for the circuits simulating a grounded plug wire. Next up will be connecting all coils and wires and debugging the code for the auto dwell function, followed by a more comprehensive test cycle with the simulator. Then connecting to a factory harness and ecu to test the est functionality. There will, no doubt, be issues found in the debugging process, but progress is being made in pretty significant steps right now.
Graham |
#118 |
This is the prototype DIS Module circuit board & billet case, that is controlling the spark firing the ignition coils in the still photo and video shown in post #106 above. It interesting to see the spark at a single coil, during the demo from idle to 8,000 rpm.
#119 |
Graham, I was wondering if you happen to know a part number for the mating connectors (male) for the two connectors (one 4 wire and one 2 wire) that plug into the coil pack? I would like to make a pig tail that plugs into the stock harness. Any help would be appreciated. thanks.
Alexco |
#120 |
Jerry,
Will the final units be potted or conformal coated? Since it will live under the hood
