Old 01-08-2020   #101
geezer
Default Re: 93 Starter Not Engaging
I don't think the Courtesy fuses are the same as illum. fuses so clarify what the RH illum. fuse feeds. As stated previously the LCD fuse feeds the Chime & Instrument panel then to the SEc. Lt.
geezer is offline   Reply With Quote
Old 01-08-2020   #102
geezer
Also the interior lights will not show with open door if the ambient light is bright. Cover the sensor in the dash ( beside TRIP/ MONITOR) with some tape & see if int. lts. work.
Old 01-09-2020   #103
RubyredEd
Interior lights not going on when door opens in pitch black garage.
RubyredEd is offline   Reply With Quote
Old 01-11-2020   #104
RubyredEd
I've been through the FSM electrical diagnosis section at length and it seems like the common denominator for all that is not working is the CCM. Is this a part that can still be gotten through Chevy? Anybody have any experience in replacing it? I know it has to be programmed so does that mean it's a dealership repair?
Old 01-12-2020   #105
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
The most likely , but unfortunate culprit.
No longer available.
Reach out to Top Toy on this Forum.
He is parting out his 93.
Perhaps he still has it.
You then will need to find one to program it.
Otherwise, your car will have his info.
I doubt that expertise / equipment is at any Chevrolet dealer, but it is still done.
Marty
Old 01-12-2020   #106
Marty
I don't a CCM can be programmed more than once.. If it can be done I am all ears, I have one I want reprogrammed
Old 01-12-2020   #107
geezer
The CCM has likely always been in the back of our mind on this however lets exhaust as many possibles as we can. I still think the Engine block ground connections should be checked & cleaned. G105 & G106 I believe. This is common to much of your issues!
It would also be appropriate to access the CCM & follow the test procedure in the FSM to actually determine a CCM failure. You will have to access the CCM anyway if you do find a replacement.
Old 01-15-2020   #108
RubyredEd
Grounds are good. Trying to find a CCM replacement before I pull it out.
Old 01-17-2020   #109
DRM500RUBYZR-1
https://corvetteparts.com/item/rebui...-bcm-1992-1993
While I am still not quite convinced for certain that it is the CCM, here is how to resolve it if it is.
They rebuild and re-program your unit.
Most CCM errors or failures cause SYS to Flash, yet you continue to have no display anywhere on the IP.
While the CCM is suspect, there just seems to be more going on.................
A pinched wire
A short somewhere on the IP
I guess it could not hurt to send your CCM in for repair, but requesting them to alert you if no trouble is found, stating that you will pay either way.
Keep us posted.
Marty
Old 01-18-2020   #110
RubyredEd
Will do. Going to wait a few days too cold in the garage right now to continue. Thanks for the advice.
