#101 |
![]() Join Date: Aug 2015
Spark Table and Fuel Table, secondaries open.. Black curve is new, red curve is old. AFR hugging 12.8:1..
#102 |
I found that the area ~ 4500-5500 rpm (max torque) is where the LT5 is prone to detonation. Beyond that, its pretty resistant to knock. The further u crank up timing at the top, the more u just see power drop, but w no indicated knock.
#103 |
Thanks Dom.. How far can I push rev limit without risk to the engine? Seems it wants to at least get another 200 rpm w/o any issue... Not chasing a number by any means, just curious about when the engine begins to roll over.. Porting heads would seem to add more "headroom" as well..
#104 |
First of all, this is absurd that I try to reply and end up witha Forbidden 404 message. And not consistently. When is this getting addressed?
Steve, I set the shift light at 7200 and fuel cutoff at 7400. From the last dyno runs I did several years ago, power peaks at 68-6900rpm. I also roll off timing after 7000rpm and fatten up fuel at that point also. Last edited by XfireZ51; 03-13-2019 at 10:31 PM. |
#105 |
