![]() Join Date: Jun 2005
With all this discussion of the DIS module, if it were me, I still had Barney and its DIS still worked, I'd get the plenum off, remove the DIS module, clean any dirt/debris of it, spray the connector with contact cleaner, clean the mounting surfaces on the module and the plenum, then apply fresh dielectric grease per the service manual.
The grease is important because its how the module sheds heat to the plenum. Hopefully the replacement DIS module project undertaken by Jerry and Graham is successful.
Hib,
Are u suggesting dielectric grease for mounting of ICM? Its white heat sink grease. Just wanted to make sure that was clear. |
![]() Join Date: Jul 2007
Actual circuit board connector
![]() Join Date: Dec 2003
UPDATE! DIS MODULE SPARK TEST !UPDATE
A significant milestone has been achieved. Graham Behan will be along shortly to add more technical in formation, but in the mean time....... Spark Load Test to 8,000 rpm. Circuitry passed with flying spark from terminal to terminal without any problem. Still photo ![]() Video with sound https://www.facebook.com/graham.beha...6792797688592/
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 03-21-2019 at 08:36 PM. |
great news Jerry
![]() Join Date: Feb 2011
Fantastic! Jerry, the Vimeo link is not working. Would luv to see it.
H ![]() |
Awesome news
#9 |
Graham has it up on Facebook. I revised the link above to show the video there.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 03-21-2019 at 08:38 PM. |
#10 |
