Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 Members' Rides
Old 10-05-2022   #101
Prez1967
Default Re: My 1990 ZR-1 #2342 from SPAIN.
I love progress updates and service pics!!!
Keep enjoying your beast!
1994 #353 "Bluey"
Prez1967 is offline   Reply With Quote
Old 10-07-2022   #102
1977CamaroZ28
1977CamaroZ28's Avatar
Good morning, I'm here again.
First of all, thanks Prez1967 for your words. I know that I'm not a expertise with ZR-1 mechanics but I hope this information and basic works will help other first owners with basic maintenance. For other big things I have my expert mechanic and here in the forum there is a big quantity of good and high level information.
In second place, last weekend I found one problem with clutch slave cylinder. I found one leak in the bottom part of clutch bell. First I thought will be oil leak from cranksahft seal to clutch but after checking the leak on the ground it was clutch fluid. Not engine oil. I checked clutch reservoir level and it was near to empty. Only two milimeters. I checked slave cylinder and I saw little leaks (I don't have pictures. I found that so late and I forgot to take pictures to the slave).
Next morning I talked with my mechanic and he confirms me that slave cylinder was still the factory one and near to thirty three years old...
I'm waiting to USPS for a new one to come to Spain. I will keep you informed.
Here you have my only two pictures from the area:
1.990 Chevrolet Corvette ZR-1
#2342 - Black/Black - March 1.990 -
OBX Headers and OBX complete Exhaust Line (No Cats).
K&N Air Filter with open Air Box.
Jerry's Gaskets Silicone Air Duct.
DeWitts Two Row Pro Series Radiator.
Samco's Hose Coolant Kit.
ECM/EPROM Improved.
MSD Spark Plug Wires 8,5mm Super Conductor.
EBC Brakes YellowStuff with EBC D-Series Rotors and Raybestos hoses.
1977CamaroZ28 is offline   Reply With Quote
Old 10-10-2022   #103
1977CamaroZ28
Still with the car stopped at home waiting for slave cylinder... I'm going to share with you other findings here in Spain.
New rear tire bag found in Madrid too. My original one has the top bitten by mouses. I don't know when and how... But the hole is remarkable. I'm looking for a good expertise upholsterer to remake the top of the tire envelope.
Here you have both:
ECM/EPROM Improved.
Old 10-10-2022   #104
1977CamaroZ28
With the same person, I found diverse little things with interest to me for the future.
One ABS Module, retainers for front calipers guide pins, ZF 6 Speed or differential cap and two aircon sensors.
And for last, one low tire pressure module receiver with two lights for dashboard panel control.
ECM/EPROM Improved.
Old 10-11-2022   #105
1977CamaroZ28
I can spend hours watching... after 9 years sometimes still I can't believe that I have a ZR-1!!!
ECM/EPROM Improved.
Old 10-16-2022   #106
Toni94ZR1
Toni94ZR1's Avatar
Hi Marcos
This DOT4 leaking issue will be solved soon
Toni Pujol
1994 Black on Black ZR1 #080
my brother is Ramon (93ZR1Barcelona)
1993 Black on Light Grey ZR1 #317
Want to belong to 500+ HP ZR1 club
350 Engine ready to assemble.
Full porting done (Heads, IH, Plenum,TB63, Air Horn)
Pete reground cams.
Fidanza
Borla+SW Heders+SW Xpipe
C5 Z06 front Brakes
DeWitts Radiator
Home made shrowd + 2 speed Motorcraft single fan.
Mopar 4.10 pinion & ring
Toni94ZR1 is offline   Reply With Quote
Old 10-17-2022   #107
1977CamaroZ28
Good morning Toni!!! What a surprise!! Welcome here!!
I hope so!! Depends on you and USPS delivery time!!
I'm very happy to see you here!! Next time in your workshop
ECM/EPROM Improved.
Old 10-27-2022   #108
1977CamaroZ28
Still with the car in the garage waiting for the clutch slave cylinder. The piece is already in Spain. I hope that in a few days it will be solved.
Meanwhile, I put another photo taken by a good friend.
ECM/EPROM Improved.
Old 11-07-2022   #109
1977CamaroZ28
I'm back again with the roaring beast!!
Last saturday my mechanic (Toni94ZR1 here in the forum, more than good profesional and better person) change old slave clutch cylinder.
The problem was with the internal washer leaking in the little rubber accordion pleats, and this, in turn, leaking to clutch bell and to the ground.
Without problems to install new piece. After that, some minutes to bleed the system.
Now the ZR-1 is again eating roads... 700 km (435 miles) in a single day.
A few pictures:
ECM/EPROM Improved.
Old 11-07-2022   #110
1977CamaroZ28
Saturday morning. 06h O'clock in the morning. Awaking the beast:
ECM/EPROM Improved.
