Old 12-09-2013   #101
icarus-54
icarus-54's Avatar
Default Re: Parting out two yes two ZR-1
back-up light switch @trans?
icarus-54 is offline   Reply With Quote
Old 12-09-2013   #102
Y-me
Have not really looked for it. This site has em for 40.00 http://www.ecklerscorvette.com/corve...1989-1996.html
Y-me is offline   Reply With Quote
Old 12-09-2013   #103
RICHARD TILL
Under the console lid there are two indentions, one for an ash tray and the other is a molded rubber insert for a drink can. I need the molded rubber. Have one?
Old 12-10-2013   #104
icarus-54
icarus-54's Avatar
The ones they sell are for a regular vette,the one for a zr-1 dosent have the pig tail,the wiring harness plugs directly into the switch.
Old 12-11-2013   #105
WVZR-1
None of the OEM/GM switches had the pig-tail but it works for and is a service part for all. In all likely hood you don't need a switch. Remove yours and clean/soak the detent ball and you should be all set. Now if it's leaking through the switch connector that's a different issue.
Y-me removes the switch he's now created a "leaker" and an "incomplete" ZF. I wouldn't think he's interested in a sale of it.
Old 12-11-2013   #106
icarus-54
icarus-54's Avatar
It's been cleaned and soaked the detent ball has been worked and there is no leak,but it still doesnt work.Guess I'll have to use the replacement.
Old 02-16-2014   #107
merkanic
I killed my transmission @ mojave mile. Do you still have one for sale
merkanic is offline   Reply With Quote
Old 04-20-2014   #108
LantanaTX
Looking for:
left and right cowl screens
the rubber fuel neck thing
drivers side of the console that has carpet attached to it for black interior
review mirror glass has some black spots if you have a good one
passenger side window if perfect condition.
Secondary fan
panel with light and fog light switch in it if nice condition, mine has gray paint rubbed off below fog light switch
Front left and right indicator/fog light lens/assembly, mine has minor cracks and staining
Drivers door pull cup if gray is in good condition, mine us rubbed off
LantanaTX is offline   Reply With Quote
Old 04-20-2014   #109
Y-me
Originally Posted by LantanaTX View Post
Looking for:
Secondary fan
Have to look at what I have when I get back, and conditions. front lenses never happen as I sell them with the entire bumper and you have to completely disassemble the assembly to replace them. As for "perfect condition" these cars were parted out for a reason, it's not like I'm parting NCRS candidates
Old 04-21-2014   #110
LantanaTX
Understood, but worth a try right? Also while going over the car, I noticed I am missing a piece of trim on the targa top. It is the small piece of trim on the rear passenger side that goes from the corner where the attachment point is to behind the passengers head. Let me know if you can help with this, but I assume this usually gets sold with the top.
