10-29-2013 | #101 |
Re: TOP END REFINISHING
Hi Schrade. See post # 18 on your page 2 . Also #37 and 41 It might help.
10-29-2013 | #102 |
Got it; thanks...
10-30-2013 | #103 |
Dry fit.
No gaskets, lube, fuel (or rails), and just few bolts. Injector assemblies are sterile as far as I'm concerned too - no need to ding up the tips. Looking for assembly sequence SNAFU's, make a gasket/etc., need list. No problems, except for a few vacuum line over/unders... Paint is Red (like SP wires). Cam flash gives that ugly pumpkin glow. Found a wire brush perfect size for the IH ports, to get out the remaining carbon on final assembly.
10-30-2013 | #104 |
This was the end of cleanup.
30lb monofilament quadrupled. Left it in the air overnight, 1/2 " over the bag. Then covered the engine, and cleaned the compressor underside. lashed at the top of 2 x 4, not the brake fluid reservoir... Afterward...
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 10-30-2013 at 03:03 AM. |
10-30-2013 | #105 |
A/C, alternator anchored, then the starter (nothing under it).
Dielectric grease on: solenoid connector: between EACH of the 5 grounding strap rings at the Coil Pac mounting grid D side corner: and while we're in the neighborhood, each of the 3 ground strap rings on the back on the P side head, after wipedown:
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 10-30-2013 at 02:11 PM. |
10-30-2013 | #106 |
Then grease on Coil Pac mount grid prongs, and grid sockets:
and the Coil Pac wire studs:
10-30-2013 | #107 | |
Worth mentioning? When you say "DIS", I believe you're referring to the coil packs and their grid mount. The DIS module is not to be confused with the coil packs, in that the DIS (mounted to the underside of the plenum) too has a critical, critical(!) thin and absolutely dirt free film of (white zinc oxide type) heat-sink grease that should not be confused with the dielectric grease shown in the pictures. The life expectancy of the DIS depends on it...Just sayin.
10-30-2013 | #108 |
Thanks there Sir...
Yep - Coil Pacs; I keep saying DIS... I don't know much
10-30-2013 | #109 |
Your doing pretty damn good for a guy that don't know much !
10-30-2013 | #110 | |
Looking squeaky clean
