Old 07-06-2010   #91
Demps
Demps's Avatar
Default Re: Coil Over Installation
*****TIP*****
Do not adjust the coil height with the shock gear attached. It may twist the gear despite your best efforts not to. ALSO, MAKE SURE THE GEAR IS SEATED PROPERLY PRIOR TO PUTTING IT ALL BACK TOGETHER!!!
Okay: what else?
Ted
Old 07-06-2010   #92
carter200
carter200's Avatar
Ted,
You have done a great job of illustrating and documenting the coil over installation kit of ours. I have some "new" pics of the upper brackets I'll post if someone can tell me how to or I can email them to someone to post.
Thanks for all your hard work on this project. I will be mailing the first rear kit to -=Jeff=- this week. With all you have to do it is appreciated that you took the time to do this, thanks again! salute
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 07-07-2010   #93
Originally Posted by Demps View Post
*****TIP*****
meaning, have the actuator removed when adjusting?
EDIT: also thanks for putting this together
Old 07-07-2010   #94
HAWAIIZR-1's Avatar
Originally Posted by carter200 View Post
Ted,
Okay, here are -=JEFF=-'s pair!!!
Here is a close up of the bracket and note how it is radiused.
Carter is one heck of a Master Machinist!!!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-07-2010   #95
SWEEET!!!!!!
Thanks Carter
Thanks for posting pics Craig
Old 07-07-2010   #96
HAWAIIZR-1's Avatar
SWEEET!!!!!!
Thanks Carter
Jeff, you're welcome.
Carter, your machine work rocks big time. I'm brainstorming the next project for you..............
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-24-2010   #97
Hey demps,
what do you mean by this:
http://zr1.net/forum/showpost.php?p=93221&postcount=94
Old 07-24-2010   #98
Demps
Demps's Avatar
I could not prevent the upper portion from rotating. Also, you cannot verify the rears are not rotating. I twistedthe rears enough that I, luckily, popped the rear actuator off-- vice damaging it.
Old 07-24-2010   #99
so to adjust ride height you need to unbolt the shock plate before turning the bottom adjuster?
Thanks for all your help/work
Old 07-24-2010   #100
Demps
Demps's Avatar
Yes. It is best. I used a strap wrench to try and hold it steady but the coil or shaft turned the top gear. I set the height I though I wanted then drove the car a few miles and let it settle.
Ted
