Old 10-31-2018   #91
jss06c6
Default Re: Plenum & Injector Housing Porting
Originally Posted by Ccmano View Post
The engine is ported and you have headers, if I’m not mistaken your running stock flywheel. What exhaust do you have?
Mine is going to the Dyno later today with Doms latest tune. We can compare notes.
H
Yes to all. I am running stock FW now. Stainless Works exhaust.. headers through tips. 3" exhaust.
Old 10-31-2018   #92
jss06c6
Steve,
Is this SAE?
Yes, SAE smoothed..
Old 10-31-2018   #93
Ccmano
Ccmano's Avatar
Looks like we’re on the opposite side of the same boat. Mine was 364rwhp today but very lean. Doms going to add fuel and I’ll go back. With these mods we should be in the 390’s...
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 10-31-2018   #94
jss06c6
My techs believe I've got another 15-20 hp when I get the WOT fueling dialed in to 12.8-13.1. I was literally spitting raw fuel out the exhaust!
Going to dial back the PE and rerun next week when I've got some time to tune on the Dyno .
Old 10-31-2018   #95
This was my dyno run w similar mods. I believe I had Magnaflow catback at this point.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-14-2018   #96
jss06c6
Loaded 10% and Inertia pass. Inertia useless in my mind, but put it on the chart as well for giggles.. 369 rwhp loaded.. Like Dom's chart, it's impressive to see the engine carry the RWHP all the way to 7000 rpm!
Old 11-14-2018   #97
Yes this is a lovely characteristic of DOHC motors. They don’t crater after peak power as do “OHV” motors. Power stays flat. That’s a HUGE advantage.
Old 11-15-2018   #98
Top Toy
Top Toy's Avatar
What happened to your torque? Was 405 ft. lbs. when it was rich?
'95 ZR-1, aqua/gray, #167
368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP.
Top Toy is offline   Reply With Quote
Old 11-15-2018   #99
jss06c6
Dyno setup had some issues.. that's resolved now. The first pass last week was accurate on the HP, but our setup for torque value was off a bit.. Now corrected..
Old 03-13-2019   #100
jss06c6
Have had some time to experiment with fuel and spark on the top end after porting #473. Slowly sneaking up on what the engine likes using an MD1100 dyno. Have eased in another 2-1/2 degrees between 5500 & 6500 @100 KPA. Max knock retard 0.5 degrees. My fuel cutoff is still sitting at 7,042. The torque is slowly rolling off, but HP is still climbing at 7,000. 406 rwhp, 374 rwtq. How far have you guys pushed fuel cutoff with a stock bottom end?[ATTACH]
