Closed Thread
Old 01-10-2017   #91
secondchance
Default Re: LED headlight upgrade
Originally Posted by Ahomans View Post
Thanks Yun. I will try that. Seems easy to before I put the housings back on.
Al
Sent from my SM-T550 using ZR-1 Net Registry mobile app
Can be done even with the housing on. There are semi-circular openings around the bezel opening to access adjustment screws.
secondchance is offline
Old 01-10-2017   #92
Ahomans
I left the housings off so I can clean them so I think I might as well align the lights first, then put the housings back on. Screws will be a little easier to get to. The housings probably don't get washed very often.
Ahomans is offline
Old 01-28-2017   #93
steve1263
Originally Posted by Billy Mild View Post
BOX:
Light:
Comparison between stock and new LED light. This is in my garage
LED Fogs, One LED headlight, and One stock headlight.
Now that I have both LED headlights the fogs no longer work. I am going to fix that.
Billy
I used the same led headlights as you, I got them here for $119 apiece:
https://www.larsenlights.com/larsen-...el-a0102-hi-lo
they work great.
As far as the fog light problem, I solved it with one of these plug and play resistors which I got here:
https://www.superbrightleds.com/more...lbs/2179/5079/
They are sold by the pair but you just need one, the resistor is a little big but it fits nicely behind the headlight bucket and it fixed the problem with the fog lights
[SIGPIC][/SIGPIC]
steve1263 is offline
Old 01-28-2017   #94
How do those resisters interface ? Do they just plug in line behind the headlight connectors ?
GOLDCYLON is offline
Old 01-28-2017   #95
edram454
edram454's Avatar
Originally Posted by steve1263 View Post
Billy
they work great.
this is the cree light that I was talking about. these are great lights and look fantastic on the zr1. easy install and great performance and look.
edramos
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
edram454 is offline
Old 01-28-2017   #96
steve1263
It has H4 male a female plugs and plugs in between the headlight and the headlight socket. Nice and easy
[SIGPIC][/SIGPIC]
Old 01-28-2017   #97
Awesome thanks
Old 01-28-2017   #98
HAWAIIZR-1's Avatar
Thanks for the great tip. Order placed and I will give the extra resistor to a friend here that is also interested in LED headlight upgrade.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
HAWAIIZR-1 is online now
Old 01-28-2017   #99
G8nightman
G8nightman's Avatar
Billy
they work great.
I use the same lights great product. Only complain i have is if you drive at night and bugs hit the Plastic on the front it will leave a stain other than that they are great.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline
Old 01-28-2017   #100
Ahomans
Steve,
Where did you get the LED fog Lights?
Al
Ahomans is offline
Closed Thread
