04-04-2014 | #91 | |
Re: Secondchance - 380 build begins!
When we ship a set of King Main Bearing to a customer, a detailed instruction sheet is included which describes the modification required. Personally, I think the King Main Thrust Bearing is better than the OEM. I have seen a few of the OEM bearing that the thrust flange welds have cracked/broken. FWIW, we also had King make +0.0005" main bearings in addition to the std size, so the main clearance could be in the middle instead of the top of the recommended clearance when building a new engine.
04-06-2014 | #92 |
04-30-2014 | #93 |
04-30-2014 | #94 |
I will run over and make sure there are no flaws, then I should be ready to ship very soon
04-30-2014 | #95 |
Looks great! Thanks Lee.
Heads are ported awaiting valve job. |
04-30-2014 | #96 |
I am going to get everthing packed up, the airhorn had a gassing issue so we are redoing it...had some pitting due to gases trying to escape the aluminum. Everything else turned out awesome, will have everything packed and over to Fedex in the next few days.
Will ship the airhorn once its redone
05-03-2014 | #97 |
05-03-2014 | #98 |
Maybe u know this already, but if that "pad" for the ignition module wasn't masked off before PC, you'll need to remove the PC before mounting the module. Can't tell from pic.
05-03-2014 | #99 |
05-03-2014 | #100 |
If not, will figure something out.
