03-16-2011 | #91 |
Re: Update on my hi-miler Z project
Maybe you could use balck upholstery piping to fill that 1/8" gap. It would finish it off without a lot of work.. Hell, if I had your money, I'd burn mine.
1994 ZR-1 # 0102...SOLD |
03-16-2011 | #92 | |
If you had my (lack of) money, you'd think you already DID burn yours. How do you think I have all this time on my hands? |
03-16-2011 | #93 |
I like the size of that amp..
here are my Arc Amps:
03-23-2011 | #94 |
Be careful about heat build up with the your amp.
03-23-2011 | #95 |
03-23-2011 | #96 |
You give me inspiration to get my 88 done.
Great work and pics!!!
03-25-2011 | #97 |
Yep, well aware of that issue in that location. I've drilled many holes in the storage area lid, and will use spacers to keep the carpet elevated a little off of that area, to allow for airflow. I think that should be adequate. Thanks for the heads up though.
03-25-2011 | #98 |
what did you have to do to make the 94 door panels fit ?. i would love to do that to my car
03-25-2011 | #99 | |
It's not a terribly tough swap. |
03-25-2011 | #100 |
Today's update:
Got the rear cargo area back together, with new(used) carpets and plastics, and re-covered speaker covers. I used a nylon 1/2" spacer under the rearmost screw holes to give some standoff from the subwoofer surrounds. Removed the original lower front air dam, it was in really rough condition, installed new aftermarket unit. Fits well and looks good. Did some major degreasing of the doorjambs. These things were filthy. Some rags and simple green, and they're presentable once again. I should have taken a "before" pic but I forgot - take my word for it, there was 20 years of grime and grunge built up there. Last edited by VetteMed; 03-25-2011 at 09:03 PM. |
