![]() Join Date: Nov 2006
Anyone know where to find the letters by the power key? Refinishing the area and they will have to go! Mine consist of " OFF ON POWER " on a 95.
Thanks
Gene in Fl. :handshak: ______________ 95 ZR-1 #399 Dunn heads X-pipe w/3" misc. mods |
![]() Join Date: Mar 2007
Good opportunity to touch base with "Sticky No More" they do Ferrari, etc.....he said he would Price ZR-1s if he saw the pieces.
http://www.stickynomore.com/
![]() ![]() ![]() Join Date: May 2007
Might be an option for those Carbon Fiber kit folks
![]() Join Date: Jul 2004
I believe it is silk screened not a decal.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
This could be a solution.
I have this sheet of what's called "velvet lettering" that I got from where I used to work on aircraft back in around 2002 (I don't know where they got it from). You just position each letter where you want it then rub firmly over the top of it with a ball-point pen to apply it to the desired surface. It ends up looking like it was silk-screened on. You could even paint a coat of clear over the whole thing to make it more durable. ![]() I used it in my '97 F-150 to redo some lettering after I painted a bezel in it. It ended up looking exactly like the factory letters. That was over 5 years ago and the letters are still there, so it holds up pretty well. ![]() If there are companies that still make this kind of thing, you could have them make a sheet of lettering for you in the correct color, font and maybe other symbols (like the "dots" next to the "normal" and "full" on the '90 ZR-1 bezels). Then for the '90 ZR-1 bezels (which are nearly impossible to find), if you needed a new one because yours is damaged or cut up (like mine is), you could get the easier to find normal '90 Corvette bezel, cut the hole, repaint if necessary & apply the lettering. This would be much harder to do with the '91-'95 ZR-1 bezels though, as those have a more complicated "box" version of the power key switch that needs a place to mount on the back unlike the simpler '90 style that is just a round lock cylinder which mounts from the front with a connector that plugs into the back of it. Or if you just wanted to repaint your original, this would allow you to re-apply the lettering to look nearly identical to factory. This would also work for the driver's door pull piece (and any other piece with similar lettering) with the mirror and window switches, although that piece has a "window" icon, but I'm sure it could be reproduced also. Does anyone know if this type of "velvet" sheet-lettering can still be purchased & customized to order?
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) Last edited by bdw18_123; 08-10-2010 at 05:16 PM. |
![]() Join Date: Feb 2010
when i installed the auto shifter in my 90 zr-1 i had to rpl the 90 bezel with one from 90-91 c4. i did not want to cut up the org. bezel, so a used one from a 90 c4 was used.
after cuttimg a hole for the power key i had a print shop make up new decals. as shown below NORMAL (upper left) SIT DOWN (instead of FULL POWER) (upper right) SHUT UP HANG ON ENG. POWER (lower left) they even got the correct color John Becker white/black #2546 one of a few auto eq since aug. 2004 Last edited by aafc; 08-10-2010 at 07:23 PM. |
You can find that lettering in arts supply stores. Used it for my drawings years ago.
And it looks good too John!
![]() Dave
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
#10 |
thanks Dave
Car is down for new trasmission. too much power for the 4l60e. broke it one week after returing form BG. installing a 4l80e to handle the 445 rwhp and 418 rwtq. hope to have back on the roar in about 2 months. John Becker white/black #2546 one of a few auto eq since aug. 2004 |
