Old 10-24-2010   #1
z proud
z proud's Avatar
Default Re: Stage 1 Porting
any dyno # for stage 1 and stage 2?
z proud is offline   Reply With Quote
Old 10-24-2010   #2
No and honestly i doubt there would be a large variance, I had planned on a dyno test but unfortunately I have bad rings.
My stage 1 is not much different than what many consider a full port job. If you are not port matching the heads you wouldn't want 36mm at the head face anyway, as there would be air turbulance from going from 36mm to 34mm(air hitting a wall)
The biggest obstacle is the Inj bosses and I take them out.
Old 10-26-2010   #3
Scrrem
Scrrem's Avatar
Still open to doing these
Stage I for $450
Stagr for $700
Lee,
Give this some consideration, what's the turn around on a Stage I job?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 10-26-2010   #4
Pretty quick, I already have a set of IH ported, I would just need to do a Plenum which only takes a weekend to complete. The IHs are black, would need to be painted or PCd
If you do not want an exchange, meaning me porting your exact plenum and IH, I would say 3 weeks. I do have a meeting in CT from 11/9-11/12
Old 11-24-2010   #5
Just an FYI, I will be trying out a Powdercoater and will let everyone know the results, he already has done a few sets of wheels for me......
Siamese port project starts soon and I will be pulling my ported intake off soon, will be available for core and $.
Old 02-19-2011   #6
Shot of what I consider Stage I...these are coming off the 90 and will exchance for stock pair for $450, the $450 includes porting your plenum. These IHs are currently black.
Old 02-20-2011   #7
Thanks for sharing, Lee. Mine (below) are modeled after Pete and Marc H's. I don't know what "stage" they would be equivalent to, but generally follow Marc's line of thinking; "...you really can't make the plenum and the IHs too big on the LT5." - don't know what "Stage" they would equate to.
But, in comparison, there seems to be a bunch more meat and flow shaping to be cut around the secondary injector boss in the pic of your IH, no? And, it looks like there is little or no expansion of the IH outlet into the heads. I'm not critiquing, but just trying to get an idea of your "Stage-I specification". For some reason, this induction design vs. performance stuff always fascinates me, I recon.
P.
Old 02-20-2011   #8
GregCrowe
Has anyone done any before/after dyno tests from just porting the Plenum and Injector Housings ?
GregCrowe is offline   Reply With Quote
Old 02-20-2011   #9
check out this post by Locobob:
http://www.zr1.net/forum/showthread.php?t=13986
