12-07-2005 | #1 |
Throttle cable clamp
Where can I find a replacement for the throttle cable clamp that holds the cables down across the plenum? Thanks for your help,
'90 ZR-1 Red/Red #1239 SGC P/P Plenum/IH, Headers, B & B, Hurst, K & N "Red RocketShip!" |
12-08-2005 | #2 |
Re: Throttle cable clamp
Should be a dealer item, I'll get you a part number in a hour or two.
12-08-2005 | #3 |
Discontinued.
But I think I have a source for them. |
12-08-2005 | #4 |
Thanks. I appreciate your help. I've seen on several Zs that these clamps have been either painted or powdercoated. Which is it?
12-09-2005 | #5 |
Mine are bare steel
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
12-09-2005 | #6 |
They are bare but have the same protective coating on them that the small pipes do for coolant and the PCV system.
12-10-2005 | #7 |
I also need one of these clamps, as well as the small torx screw that holds it in place. Let me know when you find one!
Thanks, JohnnyB |
03-24-2006 | #8 |
Found the Throttle Cable Clamps. Kurt White has them! Alll of them!
$10.00 each! JohnnyB FASTZR1 |
