Old 11-02-2009   #1
Scrrem
Scrrem's Avatar
Default Differential Case
Just pulled my differential/batwing for some gear upgrades. The case is stained from grease and road grime. Wire brushing doesn't seed to do much. Is there an aluminum cleaner out there that will help bring back the finish?
Scrrem
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 11-02-2009   #2
Default Re: Differential Case
Scrrem
I have Auto Magic wheel cleaner that did wonders to my calipers. However, it is extremely corrosive and I don't know whether it would be wise to use on a differential case.
Did you try Simple Green? Another option I can think of is to clean it real good and spray it with aluminum finish paint spray. I think Mid America sells spray paint for magnesium finish valve covers for L98.
Old 11-02-2009   #3
Scrrem
Scrrem's Avatar
Yeah, I don't know if I want to go too aggressive, I'll try Simple Green but 20 years of staining, I may be down to your painting suggestion.
Rich
Ron Davis Radiator
Old 11-02-2009   #4
flyin ryan
flyin ryan's Avatar
Sodium Hydroxide. Closest thing to it that they will sell to the public would be '409'. I buy the base chemical by the drum.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
Old 11-03-2009   #5
RICHARD TILL
I`ve used muratic acid to clean parts before but i think i`ll try the sodium hydroxide the next time. Work with it every day and never thought about it. We use about 500 gallons every other day in a vessel regeneration process. The vessel is used for boiler feedwater purification. They`ll never miss a couple gallons.
Old 11-03-2009   #6
Aurora40
Aurora40's Avatar
What gears are you going with?
Also, have you tried anything like brake cleaner or engine degreaser? I'd think they aren't damaging to aluminum.
Bob Saveland
Former owner of #2517
Old 11-03-2009   #7
Jim Nolan
What has worked for me is once you get the crud off buff it with 0000 steel wool. It also works real well on aluminum parts under the hood and front suspension.
Old 11-03-2009   #8
Scrrem
Scrrem's Avatar
4.10. Hope to get my 1/4 time down a bit for BG next year
I tried engine degreaser, it gets the crude off, but doesn't bring back the case color at all. Jagdpanzer is selling me the gears and installing for me, he may have some ideas on cleaning.
Rich
Ron Davis Radiator
Old 11-03-2009   #9
flyin ryan
flyin ryan's Avatar
I should point out that the Sodium Hydroxide I'm talking about is primarily a de-greaser, but does/can work good on aluminum finishes as well, when used correctly. The acid I use is Sulfuric Hydroflouric, it dosen't do anything for grease but on aluminum it will actually tear a microscopic layer of aluminum off. It's the stuff that some say turns aluminum white, while it does/can turn aluminum white-ish, it's not because it stained the aluminum, it is in fact because it took off the outer surface layer, what's left is the core/base aluminum. Looking back....not sure what all this has to do with diff's, LOL!
Old 11-03-2009   #10
Checking the wheel cleaner I had used, it says "Hydroflouric acid". When sprayed on it foamed and ate up all brake dust off the real nasty build up inside face of the wheels. I was cautioned to wear rubber gloves and not to breath the fume. And yes, it turned my calipers sort of white.
This stuff was so aggressive I don't knoe if I would use it on the differential case. Next time, I plan on using it only on the inside of wheels and do so with the wheels dismounted.
